Question about Pulsar Watches
Need to Replace back piece of my watch?
Need a new back piece for my watch. Can I buy a new back piece for my watch ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
No. Most likely not. Try contacting the manufacturer and give them a description of your watch. They most likely wont be able to help you becuase you need the numbers off the back of the watch in order for them to identify the watch...
Posted on Sep 13, 2013
I bought a watch and we can't get it to work. We think the battery needs to be changed.
If you take a look at the back of the watch, look for screws holding on the back plate. If there are screws (usually, if they are there there is one in each corner -- unscrew them. If there are no screws in the back of the watch, look VERY carefully at where the backing for the watch connects to the front piece of the watch. There should be a small indentation somewhere along the rim -- use a knife or a small screwdriver in that groove and pop the watch backing off.
Once you have the back of the watch off, you will see the battery right there. Sometimes they just pop out (held in by the watch back) ... sometimes there is a small piece of metal holding it in (in which case you should try to rotate the metal piece off the battery -- don't bend it).
Once the battery is out, take it to a store that sells watch batteries and match the battery type exactly (a lot of watch batteries look the same, but you need an exact match). Put the new battery in, cover it with the metal tab (if there was one) by rotating the tab back over the battery like you found it. Put the watch backing back on (and replace the screws if there were any).
Hopefully, that will kick start your watch for you, and you should be all set :-)
May 24, 2011 | Cars & Co Disney Pixar Cars Mcqueen Analog...
I need to replace battery
All you need is to open watch case back, remove the rubber seal and unclip the contact. Take the battery out (memorize polarity: + and -) and buy the same one. Fit new battery in the right way back in watch, fit the contact, place back rubber seal and refit watch case back. Reset the watch. Done.
Feb 25, 2011 | Polar M32 Heart Rate Monitor Watch
Need to replace battery in my Colibri pendant watch. Can't figure out how to open case to change it.
Thank you for contacting FixYa.
  • Place the tip of your pocket knife in the slot on the back of the watch. Pry the back off.
  • Take your tweezers and grasp the metal piece that is hiding the battery.
  • Once that metal piece is out the battery should come out too.
  • Put the new battery in and cover it with the metal piece.
  • Put the back of the watch back on and snap it into place.
  • Best wishes. Jewel
    Oct 04, 2010 | Colibri PWS-95877-N Pocket Watch
    The plastic piece that keeps the battery in place is broken.(F16059/4) is the watch
    mcdevito75 here, This is a piece of plastic is used betwen the battery and the back cover of the watch as without the plastic there is a small gap between the battery and the back cover, meaning the battery could come loose in the watch even with the back cover on the watch, replace this plastic piece with some carefully folded Scotch Tape, cut and shape the Scotch tape to Approx. the same size and thicknesss of this piece of plastic or just by sight thick enough to keep the battery in place in the watch with the back cover on.
    Aug 18, 2010 | Watches
    Remove the back, to replace the battery
    You need either a caseback knife or caseback wrench depending on whether it's a screwdown or snap-on back. If it's a snap-on, you'll also need a caseback presser to put it back on. Using the wrong tools can easily cause damage to your watch. If the watch is "water-resistant" be sure to replace the gasket as well or it will leak - you cannot reuse the gasket. You best bet to do this without having to buy tools, find the correct battery and gasket and risking scratching the watch is to let a watch shop or jeweler do it. Most places will charge about $8 to replace the battery and gasket. Sears sometimes charges only $4 so either way it's worth it. Even though I have the tools myself I usually bring my watches in and have it done since I'd have to go out and buy the battery & gasket anyway.
    Apr 23, 2010 | Columbia All Sport Digital watch
    I have lost the connecting pin link on my watch which connects the watch to actual strap, where can i buy a new one
    This is most likely a metal band and the part you are talking about is the head piece. I do not know of any outlets that sale the head piece by itself. You will most likely have to buy a replacement band either from the watch manufacturer or an after market watch band supplier like Speidel.
    Sep 13, 2009 | Tag Heuer WK1120.BB0314 Wristwatch
    Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
    hi
    please follow the steps to change the battery
    1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
    2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
    3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
    4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
    5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
    thank you....
    Apr 08, 2009 | Timex T41091 Expedition Watch
    Missing piece to Luminox 3000 black rubber watch band`
    Try parsecent.com they can get the part or a substitute part, the keeper is not sold separately tho, you would have to buy a complete band...good luck :)
    Mar 18, 2009 | Luminox Navy Seal Dive 3001 Wrist Watch
    My Aquaracer Automatic doesn't keep exact time
    you bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
    Apr 07, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Watches Logo
    95 people viewed this question
    Top Pulsar Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Pulsar Watch Expert? Answer questions, earn points and help others
