Question about Refrigerators
Proline fridge instructions
Hinge replacement for PLF140W/PLF140S INSTRUCTIONS
  • 6 Answers
SOURCE: NEED TOSHIBA 2400 SERVICE MANUAL OR DISASSEMBLY INSTRUCTIONS
Hello you can tye following url. http://repair4laptop.org/disassembly_toshiba.html Try it.
Posted on Jun 29, 2007
  • 21 Answers
SOURCE: Driver side door problems
Get a set of hinge pins and bushings. There is a tool that you can get at harbor freight or tool king for removing the bushings. I use a floor jack and a 4x4 block of wood to support the door. you will need a spring compressor to remove the door "hold" spring. Once you have that removed, you can use a brass drift or similar rod to tap the pins out. once they are out the door will be resting on the wood. I use heater hose to wedge between the fender and the door to prevent dents and scratches. tap out the bushings. ever so gently tap in the replacements. apply a generous helping of white grease to the bushing and pin. line up the door and insert the pins. you may have to apply an ever so light amount of tapping pressure on the pins to set them final. reinstall the door spring and lube the joints with white grease. be proud of yourself as your just saved a **** load of money.
Posted on Jun 01, 2009
bschilz
  • 2049 Answers
SOURCE: ThinkPad T43 Hinge Replacement Instructions
Here is a link to the Hardware Maintenance Manual from Lenovo which should help...
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6193.pdf
Here's a link to the Service and Troubleshooting Guide
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2332.pdf
Posted on Oct 28, 2009
gopakumarg43
  • 74251 Answers
SOURCE: lost instructions for proline dab radio alarm clock
Hello
Try these links.
http://www.dataentryjobs.us/67948.html
www.worlddab.org/products_manufacturers/technology/dab?pdf=1
www.digitalradioaustralia.com.au/files/...Radio/.../Reciever_Guide.pdf
Posted on Feb 09, 2012
Geekman
  • 32281 Answers
SOURCE: cover hinge broken model k52f
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br...
Acer parts are available from this WEB site.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
Posted on Sep 02, 2012
Where can I get a replacement fridge door hinge/bracket for my proline fridge LR1 thanks
you can go to the manufacturer site ,go online to appliance parts sites ,or an appliance store in your area
Sep 13, 2016 | Refrigerators
Proline fridge
Do not tighten down the hinges on the top of the unit, until it is just where you want it. They have a very large range of movement to allow for the potential of a refer box becoming out of square.
When you got what you like, then crunch down on the screws on the top of the unit.
kindly,
Jim
Jan 13, 2014 | Freezers
Proline instructions
First try different headphones. If its still bad try the same MP3 files on another player, if its still bad its a problem with the way the files were recorded. If fine on other player, take batteries out of Proline for at least 3 minutes and try again. If still bad you can either replace it or get it repaired, its far cheaper to replace it. A used 2gb player is cheaper than a bus ticket.
Dec 14, 2013 | Audio Players & Recorders
How to remove doors of a whirlpool 6vmw47 top mount fridge/freezer
Hello Hicherringto,
I understand that you would like instructions on how to remove the doors on your fridge. Most common on top mount freezers/fridges you need to start at the top and work your way down.
1. Locate the freezer hinge top part where the door swings.
2. Remove the plastic cover over the henge. (top of the box if covered)
3. Remove the screws holding the henge in place.
4. Lift up on the henge
5. Open the freezer door and lift up (the door should lift off the bottom pin)
6. Open the Fridge door and remove the screws from the hinge that the freezer door sat on
7. Remove the hinge from the fridge door by lifting up
8. Open and lift up on the fridge door
9.Reinstall in reverse
That is the easiest way to remove the doors on a top mount freezer fridge. Note that when you reinstall the doors you will have to adjust the hinges so that the seals seal properly. The hinges have enough of a grove that you use them to adjust the doors.
Thank you for choosing FIxYa.com
Justin
Apr 16, 2011 | Whirlpool Refrigerators
Written instructions for changing door on fridge freezer KGV36V10GB. Diagram is confusing!
Open door, unscrew hinge, Pull door top door off first, then remove middle hinge, then second door, then third hinge. ( good to take pic before so you know what direction the hinges are facing.
When putting on, put bottom hinge on first, then door (tape it close and in place) then second hinge, the top door (tape in place, THen finally the top hinge. Once hinges are in place, remove tape.
Jan 18, 2010 | Audiovox Bosch 718 World Cellular Phone
Do you know of online instructions to take door off a side-by-side GE Adora refrigerator model no DSS25KSRDSS? The door has built-in conveniences so I need some specific instructions on how to disconnect...
there is a cap on the top hinge-remove it--unplug the wires. then unhook the water line from the front bottom(after turning the water supply off).first unscrew the top hinge with the door shut. open the door and lift it straight up until the water tube is free. then take the bottom hinge off.
Oct 28, 2009 | Refrigerators
How do I remove Smeg FAB 28 Fridge door,as I have bought a new replacement but it has not instructions
remove the top of the fridge by removing the two screws on the back of the top and sliding the top to the back. that gives you access to the doorhinges. remove the three screews of the lower hinge, which allows you to remove the door from the upper hinge too. (sorry, non native speaker)
Oct 05, 2009 | Smeg FAB28
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
