Question about Garden
917.388740 my craftsman lawn mower was running great. a week later it would not start. the engine is a briggs and Stratton 123k02-0181-e1 the ignition module doesn't spark when I ground the spark plug and pull the cord. I cleaned the carb and bought a new spark plug
  • Allen Saxberg Jul 21, 2013
    I got another electronic module and mower still did notr start. The resistance of the new module from spark plug to gnd is 2.78kohms I cleaned the carb again and removed the spark plug to put some gas in and the mower still would not start or even show a sign of gas burning What next?
    Sergeant:
  • 337 Answers
Al clean the ignition module with some glass paper and also do the fly wheel. Should spark then
Posted on Jul 23, 2013
Testimonial: "I cleaned/sanded the fly wheel and with the new ignition module and a new spark plug still no spark. I measured the spark plug and it was open > 200 mohms. Put the old spark on and there was good spark. put gas in the spark plug hole and shot starting fluid in the carb Pulled the cord and was nothing not even a puff of burning gas. I tried a compression test but could not pull the cord hard enough too only get 4 or 5 pounds out. What next?"
  • Allen Saxberg Aug 08, 2013
    3rd sentence, add- Put the old spark plug on
  • Darin Naisbitt
    Darin Naisbitt May 02, 2014
    I might just be more uneducated than others, but I had to look up what "glass paper" was and it is basically a fine sandpaper. Works great now, THANKS!!!
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
  • 6 Answers
SOURCE: Was running stopped it for 1/2 hour, and would not re-start
IT LOOKS LIKE YOU COIL MAY HAVE CRAPPED OUT ON YOU. THEY NORMALLY WILL QUIT WITHOUT WARNING
Posted on Mar 28, 2010
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Thanks for choosing FixYa,
Kelly
Posted on Jun 28, 2011
  • 747 Answers
SOURCE: Have a 4.0 quattro Briggs and Stratton lawn mower.
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Posted on Jul 30, 2012
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
What is the air gap between the flywheel and coil on 22 hp
.030 (thirty thousands). I use brass shim material as it is not magnetic.
Jul 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
I have a 19.5 briggs and stratton engine on a craftsman model #917.270910. The starter turns engine then the engine hangs up not turning completely. briggs ans stratton mod#461707 type#0145 E1 code #
The decompressor is a valve lifter usually on the exhaust valve, the only adjustment is to correctly set the the valve clearances, if they are too slack the lifter will not activate.
Apr 21, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Have to hold chocke out to keep it running
sounds like the needle and seat is dirty within the carb
Aug 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I craftsman 20 hp twin mower quits after waarm up
SOUNDS LIKE A FUEL PROBLEM OR DIRT WHAT OTHER SYMPTONS DOES IT HAVE
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
7 hp craftsman Briggs/stratton lawmnower stalls
Your engine model # 128602 Type 0212-E1. Forget about ordering from Sears and paying shipping and waiting a week. Go to your local Briggs and Stratton dealer (most shops are) and buy part # 694395. Should cost about $3.00
May 30, 2009 | Craftsman Garden
Garden Logo
209 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
