Wdbaau0015hbk 01 how to open case
Port 01 error
There could be a problem with port (that is what it looks like).
Try opening the CASE and check for the SATA cable if plugged correctly. Plug SATA cable into other port and check that your Cables and ports are correctly functioning. Check for any garbage in the port or cable(rare).
Feb 21, 2013 | Acer Computers & Internet
My sun roof just opens up wards to vent after installing a alarm my sun roof slid all the open two times & now it only opens to vent
For sunroof related problem,if your exact car model is provided,then it will be better.But in this case,i suggest you to check the link below:----How to Remove Power Sunroof on Acura Integra? http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-power-sunroof-on-acura.html
------------How to manually close Sunroof on 2000 Lincoln Navigator? http://technoanswers.blogspot.com/2012/01/how-to-manually-close-sunroof-on-2000.html
-----------No power to Courtesy Lights and sunroof? http://technoanswers.blogspot.com/2012/01/no-power-to-courtesy-lights-and-sunroof.html
-----------This will help.Thanks.
Feb 07, 2012 | Cars & Trucks
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Hi,my WD Elements Desktop WDBAAU0015HBK hard drive is not showing on computer.how to solve?plz help me...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 23, 2011 | Western Digital WD Elements Desktop...
I have a wd hard drive that is seen by my windows 7 but i cannot see my data on the disk(ekternal memory, Western Digital Elements Desktop 1.5TB (WDBAAU0015HBK)) please help please please! its a tragedy...
all you info should be in your f drive only if didnt back it up if you did you sould save drive on disc so the system doesnt hide it on you in a program file.
Feb 14, 2011 | Western Digital WD Elements Desktop...
My computer can no longer recognize my WDBAAU0015HBK, western digital portable hardrive. I have tried everything swapping computers, USB cable, etc. All I want now is to return this hardrive (RMA) to WD...
DID YOU TRY GOING TO ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, UNDER STORAGE CLICK DISK MANAGEMENT, ENLARGE THE PAGE , LOOK FOR YOUR DRIVE, RIGHT CLICK YOUR DRIVE AND MARK PARTITION AS ACTIVE. ....HOPE THIS HELPS.......JEFFXC
Feb 08, 2011 | Western Digital WD Elements Desktop...
ASUSP4SD-VX Can not figure out how to configure plug for front USB panel to motherboard, when using this mothervoard in a generic case.
your motherboard only supports USB v1.1, make sure those are they type of connectors on your case, and if so, open this document and go to page 2-16 for diagram: http://dlcdnas.asus.com/pub/ASUS/mb/sock478/p4sdr-vm/e1104_p4sdr-vm.pdf
if the case only has USB v2.0 plugs, you cannot connect them.
Jun 28, 2009 | Computers & Internet
Can't open casing for ipaq rw6828
I've managed to open mine when the infrared screen pushed in. See the guide from the link below. Well, sorry for my bad English in the guide... :D
http://adhi.widjajanto.net/blog/archives/2009/01/how_to_open_hp.html
Jan 08, 2009 | HP iPAQ rw6828 Smartphone
Chefmate HB-215
My book doesn't have an error message E-07, only E-01 and E-02. Both error messages will beep.
E-01 means baking area too hot. To reset open lid and remove bread case to cool. After panel message disappears replace bread case and press start.
E-02 means baking area too cold. Unplug unit and allow it and the baking area to warm. Then try again.
Hope this helps.
Oct 12, 2008 | Chefmate TR 7000 Bread Maker
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
