Question about OES Genuine 2007 - 2008 Dodge Sprinter 3500 A/C Compressor Relay W013
Where is a/c relay location 2008 dodge sprinter.
Problem with sprinter 2008 dont start
Have you run fault code tests? Does the starter spin and engine turn over but not start? I need more details.
Jun 17, 2016 | 2008 Dodge Sprinter
What is the code p0473 for a dodge sprinter van 2008
Error Code: P0404
Fault Location:
Exhaust Gas Recirculation (EGR) System - Range/Performance Problem
Causes:
-Hose leak/blockage.
-Wiring harness.
-Exhaust gas recirculation (EGR) valve/solenoid.
Error Code: P0473
Discription:
Exhaust Gas Pressure Sensor - High Input
Causes:
- Wiring short to positive.
- Exhaust gas pressure sensor (G450).
- Engine control module (ECM).
Error Code: P0674
Description:
Glow Plug Cylinder 4 Circuit - Circuit Malfunction
Causes:
-No Pre-Glow Period.
-Poor Cold Starting.
-Glow Plug Wiring faulty.
-Poor connection.
-Relay.
-Glow plug control module.
-Glow Plug faulty.
-Engine control module (ECM).
Solutions:
Check Glow Plug Wiring.
Check Glow Plug.
Error Code: P0675
Description:
Glow Plug Cylinder 5 Circuit - Circuit Malfunction
Causes:
-Poor connection.
-Relay.
-Glow Plug faulty.
Solutions:
-Check Glow Plug Wiring.
-Check Glow Plug.
Sep 20, 2014 | 2008 Dodge Sprinter
Fuel filter location
The fuel filter is located inside of the fuel tank and is only serviceable as a unit with the fuel pump, fuel pressure regulator, and the fuel filter.
Jul 26, 2014 | 2008 Dodge Sprinter
What is a particulate filter?
Hi there a Particulate Filter is a device fitted to diesel vehicles that remove soot from the exhaust gases exiting the engine, they are normally located under the vehicle between the downpipe and back box.Hope this Helps
Nov 20, 2012 | 2008 Dodge Sprinter
Reset check engine dodge sprinter 2008
use a obd2 scantool.
try disconnecting all the battery connections. works on some cars.
Sep 16, 2012 | Dodge Cars & Trucks
2008 Dodge Sprinter; key will not turn to start position. worked before changing the battery out.
If the vehical will not turn over, check all battery connections. If the key is stuck, try moving the steering wheel so the vehical is not locked up.
Apr 17, 2011 | 2006 Dodge Sprinter
How do you remove radio from 2008 dodge sprinter
two holes either side .push a couple of welding rods in either side that works ,this is a mercedes sprinter i take it
Dec 19, 2010 | 2007 Dodge Sprinter
I just need a chart for dodge sprinter 2008 check engine codes...
try.. http://sprinter-sourse.com/forum/showthread.php?t=7608
Jul 07, 2009 | 2007 Dodge Sprinter
OES Genuine 2007 - 2008 Dodge Sprinter 3500 A/C Compressor Relay W013 Logo
61 people viewed this question
Top OES Genuine GPS Experts
Lawrence Oravetz
Ron Reynolds
Are you an OES Genuine GPS Expert? Answer questions, earn points and help others
