Question about Refrigerators
Service Manual for Chefmate BC-50A Mini-Refrigerator?
Can anyone help me locate a service manual for a Chefmate BC-50A mini-refrigerator? Mine is dead (no cooling, no fan, when plugged in) and I was hoping to repair it myself. Thanks!
SOURCE: Refrigerator
I had the same problem with my refridge it is a very bad product at first it worked perfectly fine made everything inside it nice and cold but now it barley gets cold at all ANY HELP on fixing this problem and making it cold again thanks
Posted on Jun 02, 2008
  • 958 Answers
SOURCE: I punctured the freon channel
you have to bring it for repair.
the repair that they would do if they know how to is to weld the puncture hole by aluminum brazing , they may want to check the oil in the compressor in order to be sure that no water have been sucked by the compressor from the hole in the evaporator.
evacuate the system and charge it with the right amount of the correct refrigerant.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
woodchuck789
  • 4059 Answers
SOURCE: Need a service/repair manual for a Kenmore refrigerator.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 4 on this diagram is your timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=1069608210&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&diagramPageId=00003&componentDescription=COMPARTMENT%20SEPARATOR%20AND%20CONTROL&documentId=00050440&backToLink=Return%20to%20subcomponent%20list
Posted on Aug 13, 2009
miket756
  • 2702 Answers
SOURCE: I have a Chefmate Mini Fridge - BC-50A that does
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Posted on Nov 19, 2009
  • 12173 Answers
SOURCE: NEED FAN MOTOR FOR CHEFMATE REFRIGERATOR MODEL#
remove motor and use the numbers on motor for replacement most appliance, hvac,and electrical supply stores even online carry replacement
Posted on May 06, 2010
I have a Chefmate BC-87/H mini fridge and I lost my Manual and I need to know if #1 is coolest or #9
jeeze! none of these idots who replied are reading your question!!! I have the same issue not sure which is warmer and which is colder. in my full size fridge, 1 is warmer, and the higher numbers are colder. if you found the solution though- i would really appreciate it if you could let me know! my email is mike41062@gmail.com... i have been searching for the user manual online and cant find it anywhere. cant even find a website for chefmate!!!
Sep 21, 2010 | Refrigerators
Will not cool light does not come on when door is open Chefmate Model: BC-50A
unplug, take the back cover off.
Look at the circuit board.
at the top right of the board there is a fuse.
if it is blown, the frige is dead.
you will probily find that there is a brown burn mark
on the upper left side of the circuit board under an aluminum
heat sink. that electronic part probily overheated and blew up.
unless your electronics skils are up to it throw the frige away.
but if you are up to it unsolder it, bring it to frys electronics, and
get a new one. Good luck.
Aug 25, 2010 | Refrigerators
NEED FAN MOTOR FOR CHEFMATE REFRIGERATOR MODEL# BC-50A SERIAL# 060511869
May 06, 2010 | U-Line 15R Compact Refrigerator
I have a Chefmate Mini Fridge - BC-50A that does not work. It appears the heat sink fan and the cold sink fan do not have power to the motor. What do I do? nicole.barnes@parknicollet.com
Nov 19, 2009 | LG GC-051SS Compact Refrigerator
I need to find the manual to the Chefmate mini fridge BC-87/H
Hi, get me a model # and I can look this up for you and try ans assist you.
Thanks
Vic
May 17, 2009 | Refrigerators
Settings for a chefmate refrigerator.
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Nov 27, 2008 | Kitchen Appliances - Others
Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
Nov 03, 2008 | LG GC-051SS Compact Refrigerator
Refrigerator
Jan 03, 2008 | Refrigerators
Refrigerators Logo
624 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
