Question about Garden
28cc what does 28cc mean on a husqvarna trimmer
4 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: Husqvarna 28cc weedeater primed x3...choked
This sounds like a fuel starvation problem. These units use temperamental little diaphragm carburetors which can develop assorted ills and problems. Sometimes, the problems stems from debris in the carb, fuel tank, fuel filter, or inside the carb where there is another very fine filter. You have stated that it runs 30 seconds, but I don't know if it is IDLING for that period or running at speed for that period. At any rate, check the in-tank fuel filter, ALL fuel lines, and if you can remove the fuel pump cover on the carb (it does NOT have a vent-hole), and check inside where the little round fine wire mesh screen is. Check it for debris.
If all the above are OK, then the carb may just require a small adjustment. The problem here being the type of screws used to adjust the Low and High speed mixtures on the carb. Some have splined heads, some have Pac-Man shaped heads, some have D shaped heads, and some have Double D shaped heads. Older ones have conventional slotted screw heads. On the non-conventional ones, you can use automotive type wire terminal spade connectors. Before you put them on though, you need to note the exact position of the mixture screw you are going to adjust. After that, tap the connector onto the head of the screw. If you use a female spade connector (22 gauge or so), then the end of a small flat blade screwdriver will fit the spade and you can turn the screw. I will refer you to an excellent Zama (probably your carb) carburetor adjusting tutorial now.
http://www.zamacarb.com/tipspage.html
Try these things and feel free to post back. We will continue to try to help with your issue.
Posted on Aug 06, 2011
  • 316 Answers
SOURCE: pope line trimmer 28cc cord replacment guide
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ~~
Posted on Feb 19, 2012
barbaraepper
SOURCE: Have a 28CC Husqvarna 2 stroke engine. Used it once, now the attachments won't slide far enough in to connect to the drive shaft and
Sounds like the upper drive shaft connected to the trimmer housing has slid down. Try holding the unit gas tank down, and turn the inner shaft until it drops back down into the unit, then attach the desired tool.
Posted on Jul 24, 2012
Trimmers hesitate and quit running
Check fuel is getting into the cylinder, check you have good compression, check you have a good strong continuous spark. Once you have checked all these, please provide more information. Thank you
Jul 05, 2012 | Husqvarna 28cc Gas Line Trimmer
Jun 28, 2012 | Husqvarna 28cc Gas Line Trimmer
I just need to know the gas to oil ratio mix
40 to 1
means 40 units gas and one (same size) unit of lawmower oil
May 21, 2011 | Husqvarna 28cc Gas Line Trimmer
Where can I get parts for the pull starter on a 325c husqvarna trimmer?
You can shop for parts online, of speak to your local husqvarna dealer
Apr 25, 2011 | Husqvarna 28cc Gas Line Trimmer
I have a husqvarna 22r. where can i find a replacement trimmer head?
You can buy them online,or speak to your local husqvarna dealer
Mar 03, 2011 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
