You will have to remove all the cowlings from the steering column to access the ignition lock and switch. With the correct key inserted and selected to, probably, the ACC position, you should be able to push on either a pin or a tongue that protrudes from the switch into the housing and the pull the whole lock/switch mechanism out.
need a special tool to remove the locking plate behind steering wheel then pull turn signal switch back a little then remove screw that keeps lock cylinder in place
