Question about Garden
Bunton b36-125k drive belt routing diagram needed
It threw the drive belt. I am replacing but cant figure out the routing so I can adjust the speed
PyroPCMan
  • 405 Answers
SOURCE: Drive Belt
1ab6618.jpg Fig. 29: Drive belt routing-1996-98 4.3L, 5.0L and 5.7L engines
Hope this helps
Posted on Jul 02, 2008
old marine
  • 1986 Answers
SOURCE: need routing diagram for 2000 lincoln town car serpentine belt
There's a diagram at this link.
Posted on May 11, 2009
  • 67 Answers
SOURCE: need bunton 48
good luck buton went out of bus a long time ago you can try Jacobsons web site they now own them
Posted on Sep 01, 2009
  • 3 Answers
SOURCE: 99 Beetle Serpentine belt diagram
The serpentine belt on my 2001 Beetle loops around the outside of the large pulley closest to the firewall, at the bottom, then goes around the outside of the forward lower pulley, then crosses to the inside of the one right above the forward lower pulley, then loops over the outside of the alternator pulley at the top front side, then goes inside under the tensioner pulley, and back down to the outside of the big rear pulley.
I hope that description makes sense. A picture would work a lot better, but I don't have an easy way to post it. Also, I know you asked about the '99 Beetle, but I assume its routing is the same as the 2001 (which is the one I have).
Posted on Sep 14, 2009
mowerman1857
  • 389 Answers
SOURCE: Poulan mower throwing the belt.
1) Remove the cover on the top of the belt and
remove the belt from the transmission pulley
2) Lean the mower back on its handle and secure it
with whatever you have that will keep it there while
you work on it, any heavy object will do
3) Remove the blade bolt, the blade, the blade
adapter and the plastic belt guard from the bottom
You should now be able to remove the belt
4) While you have the belt off, closely inspect the
pulley on the engine shaft, they sometimes get
grass built up in the groove and this will cause
the belt to run off and also wear prematurely.
Hope this helps you out
Chuck
Posted on Nov 05, 2009
Need a diagram for replacing the belt
For all types ofTiming belt routing diagrams for cars and trucks?Click the link below:---http://technoanswers.blogspot.com/2011/10/timing-belt-routing-diagrams-for-cars.html
For all types of Drive belt routing diagrams for cars and trucks?Click the link below:---http://technoanswers.blogspot.com/2011/10/drive-belt-routing-diagrams-for-cars.html-------------Thanks.
Jan 20, 2012 | Cars & Trucks
Need belt routing diagram gmc 2500 6.6 duramax
I need a belt routing diagram for an o 06 Duramax with air ps etc
Jun 29, 2011 | 2006 GMC Sierra 2500HD 2WD
I need to find the diagram that shows how to reassemble the deckj belt on a bunton zero turn mower
You can download an owner's manual from this link. It may or may not have the belt routing schematic, but I'm betting it does. You will need to input the model number of the machine you have to enable the download.
http://cgcequip.arinet.com/scripts/EmpartISAPI.dll?MF&app=CGC54&TF=EmpartWeb&partner=CGCSB&lang=EN&loginid=CG999997&loginpwd=2006CGC1030
This long URL reduced to size is:
http://tinyurl.com/3qgjlgd
Apr 15, 2011 | Garden
Replacing broken drive belt.
look under foot rest on tractor usually there is a diagram under there for belt routing and also sometimes on the mower deck it's self
Jun 24, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
Diagram for fan belt repair
2.0L Engines
See Figures 11, 12 and 13
The accessory drive belt for 2.0L engines has no provision for manual belt adjustment, since these engines use an automatic belt tensioner. Drive belt slack is taken up by the automatic tensioner.
Movement of the automatic tensioner assembly during engine operation is not a sign of a malfunctioning tensioner. This movement is the tensioner self-adjusting and is required to maintain constant belt tension.
The belt tensioner has a belt length indicator. If the indicator marks are not between the MIN and MAX marks, the belt must be replaced.
0900c1528008d836.jpgFig. 11: Drive belt routing-2.0L SOHC engine with A/C 0900c1528008d837.jpgFig. 12: Drive belt routing-2.0L SOHC engine without A/C 0900c1528008d838.jpgFig. 13: Drive belt routing-2.0L DOHC engine
Aug 25, 2008 | 1998 Ford Escort
Serpentine belt replacement
2.0L Engines
Jul 24, 2008 | 1999 Ford Escort
Garden Logo
2,061 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
