Question about Ideaworks Instant Internet TV Radio USB Stick
Unable to install new tv/radio usb stick to laptopJobar Internationa
Hoow do i download mobdro onto my toshiba smart tv
download it on a usb stick via a computer. you need to look for ..mobro apk .when you find and download it put the apk file on usb stick.and stick it in usb on tv .install .done
Jan 22, 2018 | Toshiba Televison & Video
Setting up fireTV stick. It's plugged in to TV and power.ts Tried all inputs on TV. None worked. What am I doing wrong???
not sure if this link will help you out.
1. The easy way (5 mins)
  1. Plug your Amazon Fire TV Stick into your TV and plug the USB power cable into a spare USB port or use the power adapter.
  2. Go to Settings. ...
  3. Go back to the homescreen and install an app called Downloader - this will be listed under the Popular Fire TV apps section.
More items...
How to install Kodi on the Amazon Fire TV Stick: 3 BEST ways to ...
how to set fireTV stick Google Search
Oct 28, 2017 | Televison & Video
Can i install a amazon fire tv stick the u s b will not plug in
Amazon.com: Customer Reviews: Amazon Fire TV Stick
www.amazon.com/Amazon...Fire-TV-Stick/.../B00GD...
Amazon.com, Inc.It doesn't even play all the games that can run on the Fire TV box. Also note ... Q: CanI use my TV's USB port to power the Fire TV Stick? ... A USB port on your TV or other equipment probably will not work. ..... You can plug the Fire Stick's USB cable into theUSB port on your TV and it should work (depending on your TV ).
Amazon.com: Customer Discussions: Fire stick and Samsung TV issues
www.amazon.com/forum/fire?cdForum...cdThread...
Amazon.com, Inc.Getting a brand new replacement from Amazon did not help, seems to be some other HW or SW issue. Anyone else run into similar issues? ... I also have a Samsung TV and the Fire Stick is not recognized through HDMI or USB connections. .... Can youplug the HDMI extender cable into your TV and will the Fire TV stick fix
Dec 25, 2015 | Sanyo DP42849 42 in. HDTV
I am unable to get my audio system to read my USB stick,to play music on my Panasonic mini system
Try to format your usb flash key with diferent file system example ntfs or fat32. If it will not work try to install diferent format of music into flash drive example wav
Nov 06, 2014 | Panasonic Sc-Hc37 - Micro System - Radio /...
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that...
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
Sep 03, 2010 | Televison & Video
I do not have a disk drive and am unable to install my deskjet f380 into my new laptop
You can copy the printer drivers on to a USB flash memory stick from another computer and then insert this USB memory into your new laptop USB port and install the printer driver.
Apr 04, 2010 | HP DeskJet F380 All-In-One Printer
Do i need to set my lap top to be able to watch tv.if so what ?
you can watch tv tuner its USB device for laptop allow to watch or install softwarefor more information refer to http://laptoplogic.com/resources/detail.php?id=46 you can getinformation about tv tuners
Nov 18, 2009 | Compaq Presario CQ60-220US PC Laptop
Ideaworks Instant Internet TV Radio USB Stick Logo
231 people viewed this question
Top Ideaworks Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ideaworks Audio Player and Recorder Expert? Answer questions, earn points and help others
