Question about Ariston Technologies Washing Machines
Ariston atd 104 code problem F 12
Good evening I'm techniques k I have a problem with a Washer MACHINE MODEL ARISTON ADT 104 says fault code F 12 and passes continuously water.
  • 1294 Answers
SOURCE: ariston awd 12
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Mar 30, 2008
SOURCE: ariston a1636 washing machine
I have the same problem, did this get solved for you?
Posted on May 18, 2008
SOURCE: ariston 6kg washing machine
Do you have the "easy iron" feature on? If so, the clothes will stay in water until you manually rinse it.
Posted on Jun 13, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
Posted on Jan 23, 2010
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
Sep 13, 2014 | Ariston Technologies Ariston AWD12 Front...
Ariston awd 1200 fills,advances and empties, but will not wash or spin.Belt ok, drum rotates free. Any advise?
The fault is on the motor control board, which is on the bottom left when looking from the back of the machine. There's a good chance that one on the connectors will have over-heated and burned the track. I fixed ours by utilising an unused connector on the board and swapping the pins in the connector.
Mar 23, 2013 | Ariston Technologies Ariston AWD12 Front...
Ariston washing machine. Error code F09
Most Indesit ( Hotpoint, Ariston) machine's 'F09' decodes as ' incompatible eeprom' or eeprom error, check/change eeprom'. Sorry, whichever it is requires an engineer call ;-0(
Hopefully it might only need connectors reseating.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | Ariston Technologies Washing Machines
Ariston dryer model asl65vxs flashing F-12
F-12= communication error
Could be bad connections, wiring faults or a bad board. You can try unplugging the dryer and checking connections,wiring and the board for burnt or bad connections. Hope this helped Tim
Apr 29, 2011 | Hotpoint Ariston ASL65VXS Electric Dryer
Our Ariston AWD12 keeps cycling through programs. Engineer has replaced lots of parts but problem not fixed. 13 flashes showing as it clicks round.
Th e fault code indicates a problem with the dryer fan or the thermistor as being the cause of the problem. Check for broken wire.
These are located in the top of the washer, access is gained by removing the top cover.
Jan 15, 2010 | Ariston Technologies Ariston AWD12 Front...
Hariston margarita a1324 advantage
hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 13, 2008 | Ariston Technologies Ariston AWD12 Front...
Ariston a1636 washing machine
Jan 08, 2008 | Ariston Technologies AW149NA Washer
Washing Machines Logo
101 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
