Hi, i have hp dv5 1150us laptop. Its charging light is constantly blinking as soon as the os boots up. Charger is working for sure. I tried to replace with other battery, still its blinking. I guess theres some problem with the battery connector. What do you think?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Hi
try the following:
remove the battery then press
power button to drain all the current
then resit battery and plug to adaptor
Thanks
Posted on Jul 22, 2013
  • 69 Answers
SOURCE: Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Posted on Oct 08, 2008
  • 24 Answers
SOURCE: medion 2310 laptop switches off as soon as charger is plugged in
1. It can be a screw loose inside the unit shorting something out.
2. The AC Port is damaged and needs to be re soldered.
3. Bad motherboard.
I've seen this be a bad motherboard more than not, however it has been the other 2 options from time to time. Most likely need to take it apart and you can see if it's the first 2 and if not than your board is bad.
Posted on Nov 10, 2008
asish_shrm
  • 121 Answers
SOURCE: battery and or charger
Hi you have mentioned
"Sometimes if I jiggle the AC adapter connection to the laptop when the battery icon starts flashing I can get it to continue working."
Looks like you have a lose jack on your notebook or the adapter itself....try to shake the connections when fitted to the notebook and check weather its the adapter or the note book jack....
If you dont have experience opening your notebook and soldering or soldering your adaptor end i suggest you take it to repair center
keep me posted
Cheers!
Posted on Nov 14, 2008
  • 1768 Answers
SOURCE: HP DV6915nr AC charger does not turn on or charge the battery.
You have a defective regulating circuit on the mother board that will not allow charging or a broken connector pin at power connection .
Posted on Aug 13, 2009
SOURCE: My Dell Inspiron 6400 battery is overheating and light is flashin
Hello I own a Dell Inspiron 6400, i guess what happened was that it must have overheated of so but its on the screen your system automatically powered off because it became warmer than expected. This may have been caused by:o) operating or storing the system in an environment where ambient temperature is too high or o) obstructing the air flow from the system fan vents. if this problem recurs please call dell support with error code #M1004. strike the f1 key to continue. f2 to run the setup utility pressf5 to run onboard diagnostics.
Posted on Aug 03, 2010
Laptop dose not boot no boot noise
Hi Johathan, Are there any lights on your laptop that are either steady or flashing? Start with the simple things first, make sure that the battery is charged up or use the charger cord, Do you see anything on the screen at all? even a flashing cursor?
When posting a question, try to give us the model number of the laptop so we can research the problem more thoroughly.
Thanks
Oct 02, 2013 | HP Pavilion Computers & Internet
My Pavilion g6-1b79dx notebook will not charge even with a new battery and charger. The light indicating the charger is plugged in is blinking white
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/replacement-hp-pavilion-g6-ac-adapter-19v-90w.html
Dec 09, 2012 | Plantronics Hp - Pavilion G6-1B79Dx Laptop...
Blinking blue and orange light when trying to charge
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
May 17, 2012 | Packard Bell Computers & Internet
I have a HP Compaq CQ50-130us notebook. Yesterday I had it on and it just turned itself off after that I tried turning it back on the power button lights up and the cd drive you can hear turn on. But it...
hi aliyoow, i am happy to assist you, Step - 1 did you check whether your laptop is working without battery , just take your battery out and plug your charger in DC jack and check whether your laptop is getting on or not. If it get on mean you have problem with battery.
Step 2 - Use some-other charger of your friends laptop which is same averatec laptop and check whether your laptop getting charge or not. if your laptop get charge mean you have problem with your charger. if you change it , i will start to work again.
Step 3 - take you charger put in some-other laptop find-out it charging that particular laptop or not, if it get charge mean your charger was is good condition you have problem with your DC jack.
Step 4- take your charger put in DC jack on your laptop switch on power and try to move it side wise softly right and left and top and bottom check whether your charger light glow in your laptop , if it get glow at any point mean you have problem with your DC jack so try to change it so that you can able to bring back your laptop normal working mode.
If you have warranty on the laptop you can directly go to showroom and change it , they will help you without cost. if you don't have warranty just check the steps i have mentioned.
Good luck ! if you think your problem solved don't forget to rate
Jan 02, 2011 | Computers & Internet
Hi i am having a problem with my HP compaq nc6220 laptop my OS is crashed i think when i insert OS CD as soon as the setup starts the machin shutdown
you need to change the boot order to start the PC on the CD driver.At start up press F2 or F12 i not sure just look it before the OS logo appears.at the boot menu change the boot to the CD driver.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | HP Compaq nc6220 Notebook
Plug in charger for laptop hp g60, but not charging. How can I find it works?
Try charging the laptop without the battery. If it does not work, Check the port of the charger if it blinks any light. If it doesn't, then I guess you would have to get a new charger. If it still does not work, then the power pack should be examined by an expert.
Sep 20, 2010 | HP G60-230US Notebook
My Dell 1501 laptop turns off as soon as the charger is connected
Sounds like you have a multiple problem going on here honestly. If you have a constant light on your charger even when its completely disconnected from the wall outlet then your charger is bad for sure, cause the light shouldn't come on unless the charger is hooked up to power.
Your battery maybe shorting out the laptop which is why it needs to be taken out for a bit before the laptop will turn on.
My suggestion would be to try a known good working charger on your laptop to make sure it turns on properly and stays on without the battery hooked up.
Then if your laptop stays on for a while then with the laptop on and the charger hooked up, connect the battery again and see if the laptop will charge up the battery to 100%. If it does then disconnect the charger and see if the laptop stays on with just the battery hooked up. It could be that the battery is drained beyond 0% and just needs a good charging. If you can't charge up the battery or the laptop still turns off to where you have to take out the battery to get the laptop to turn on then the battery is bad and would have to be replaced.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
Laptop not booting up and nothing showing up on the screen
What leds you can see blinking on laptop? Can you hear any bootup sounds? Sometimes my laptop hangs on standby or hibernat, then screen is black and some leds may blink. Usually i need to take charger and battery off for 10 seconds and boot up again. If that dont help then there must be some hardware damage.
Jan 27, 2009 | HP Pavilion FE849UA Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
