Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Board all led are flashing and blinking.then baser is turn on. this is a common fault.pls give me a alternatives.
  • 130 Answers
Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Posted on Jul 23, 2013
I just plugged in and turned on my 7462 singer machine. It has a high pitched alarm and all LED lights are blinking. What is going on?
Check the troubleshooting section of the manual. Otherwise, it would probably be a good idea to take it for service.
May 21, 2017 | Singer Sewing Machines
Blinking Red led on Pfaff 7570
Make sure the bobbin has thread. The manual should provide information in the troubleshooting section.
PFAFF creative 7570 Instruction Book
Nov 13, 2016 | PfaFF Creative 7570
Display does not light up on PFAFF 1475 CD
Could be an electronic issue. Take it to your local Pfaff dealer for an estimate on repairing it. The parts may or may not be available.
Feb 01, 2015 | PfaFF Sewing Machines
The power switch is bad on my bernina sewing machine
I would suggest taking the machine to a sewing machine repair shop, since it's a Bernina.
Nov 10, 2014 | Bernina Artista 170
Led light does not work. how to replace led light on singer 14sh654
I believe the newer machine lights need to be replaced by a technician. You can check on getting some of those LED light strips that can be added to the machine instead.
Jun 24, 2017 | Singer 14SH654
I have a Pfaff creative 1471. When I turn it on the light flashes across like normal, but the computer display is blank. The normal little reset of the machine does not occur and the machine will not run....
The 1471 is getting on in years. It is not uncommon for the PC board to develop a fault. It can be replaced, however, cost is prohibitive unless you can find a repairer with a 'good' used board.
Good luck
Oct 19, 2013 | Kenmore 15218 Mechanical Sewing Machine
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
When I went to turn on my activa 130 it does not turn on. The screen just blinks.
sounds like connection problems with the board inside. a short of somekind. needs to be checked out.
Aug 17, 2010 | Bernina Activa 130
Memory Craft 8000 LED is not lighting up bright enough
This is getting to be a common problem on this machine.The only way to fix this problem is to take it to an Authorized Janome Dealer who can remove the circuit board, send it to Janome for a rebuild and reinstall it. Plan on spending more than $300 including the servicing that should be done at the same time. This is a good machine and it is worth the repair unless you just want a new one that is a little easier to use.
sewman7
Apr 07, 2009 | Janome Memory Craft 9000 Computerized...
Flashing lights
This is a copy of the post on your premium solution thread.
According to Singer guidelines , if there is only red blinking light, then there is an fault inside the machine, unless it reset disconnecting from power.
If there is an error code with format EM-01 - EM-09 tell me which error you get and I should find a fix.
Here is a complete user guide, check pages 90-92 for common errors.
If you have no error message, and light does not go out with power disconnect then it may be a faulty control board.
In this case I suggest doing a last attempt removing all threads, and reset design unplug from power 10/15 mins.
Let me know if you still have the problem.
Regards
Apr 12, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
76 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
