Question about Ariston Technologies AWD121WH
F12 error code
Good evening I'm techniques k I have a problem with a Washer MACHINE MODEL ARISTON ADT 104 says fault code F 12 and passes continuously water.
  • 1294 Answers
SOURCE: ariston awd 12
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Posted on Mar 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
  • 3741 Answers
SOURCE: Ariston AIB16 flashing fault code f-08? can this
F08 Heater relay cannot be activated
this can be repaired cheap its part of the main board
If it works fine with the heater off then i would say that fault appears to be element..the readings you get seem okay, put you meter onto megs and check, with wires off if you get electrical leakage between live and earth...Body....of element, it could be element is heating with no water in machine causing it to burn out..this is a problem with this machine
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 28, 2009
  • 1416 Answers
SOURCE: I have the error code 5 on the Ariston washer
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
Posted on Jun 07, 2010
  • 713 Answers
SOURCE: hi sir we have ARISTON washer and dryer model :
unplug it for a few min. plug back in.
Posted on Mar 01, 2011
I have a Bosch Maxx WFL 1662 washing machine. It does not stop washing and go over to the rinses sickle.Where do i start looking for the problem?
Hi Eric, There's two links below... 1st link is Bosch Washing Machine Error Fault Codes and the 2nd link is worth reading, The master reset is only part of the trouble shooting, I hope these help.
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 02, 2016 | Bosch Washing Machines
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
Sep 13, 2014 | Ariston Technologies Ariston AWD12 Front...
I have a Ariston Avtxf 149 that is locked down with f12 error mode.
F12 is a communication error.
The electronics aren't talking to each other properly.
F5 means the Pressure Switch jammed on full
Possible pump block, check pump etc. for blockage
Check pressure switch, wiring and module connections. Also in the first instance check the drain pump filter for any blockage or, if there isn't a drain pump filter fitted the pump will need to be removed and inspected for any blockages.
May 28, 2012 | Washing Machines
Fix code 104
104. (01101000) See Fault Code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jan 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Ariston washing machine. Error code F09
Most Indesit ( Hotpoint, Ariston) machine's 'F09' decodes as ' incompatible eeprom' or eeprom error, check/change eeprom'. Sorry, whichever it is requires an engineer call ;-0(
Hopefully it might only need connectors reseating.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | Ariston Technologies Washing Machines
Ariston dryer model asl65vxs flashing F-12
F-12= communication error
Could be bad connections, wiring faults or a bad board. You can try unplugging the dryer and checking connections,wiring and the board for burnt or bad connections. Hope this helped Tim
Apr 29, 2011 | Hotpoint Ariston ASL65VXS Electric Dryer
Ariston Washing machine A1636 - Flashing lights
what 2 lights are flashing each light that flashes gives a differant fault code . Get back to me
Jun 20, 2007 | Ariston Technologies AW149NA Washer
Ariston Technologies AWD121WH Logo
27 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
