Vauxhall insignia faults how long to change air con condenser is it bumper off ?
2 Suggested Answers
  • 52 Answers
SOURCE: common problem and solution on condenser of carrier air con.
dirty evaporator filter and or coil, dirty out door condensing coil, defective thermostat.
Posted on Mar 07, 2010
Vauxhall insignia 2.0 petrol turbo engine management light started coming on and fault reads p000b what do I change ( engine doesn't miss a beat when light comes on)
code p 000B refers to cam shaft position (CMP) actuator , exhaust/right/rear bank 1---slow response ===causes wiring---CMP actuator--ECM
this is the unit that advances the valve timing at higher rpms and will not affect the engine performance noticeably under normal engine rpms
you may see it as increased fuel consumption
However that said it is advisable to take it to an accredited service center that has experience on your make of vehicle and have the matter investigated and fixed
Oct 29, 2016 | Vauxhall Cars & Trucks
Where can I get a Vauxhall insignia Sri petrol 2012 manual
Hi Anonymous, The link below is a FREE 253 page owners manual for a vauxhall insignia model 2009 to 2015.........CHEERS..
http://insignia-enthusiast.org/owners%20manual.pdf
Apr 30, 2016 | Vauxhall Cars & Trucks
Vauxhall insignia cooling fan running constantly but not overheating
If the Ac is on then yes the fan will run ,but if a uk reg car no doubt it has no AC so check if the AC is on first if its not and the fan is still running then you have a temperature sensor fault ,what one and where ??
May 30, 2015 | Vauxhall Cars & Trucks
Air con condenser change out 2007 golf
Hi the front buper gets removed and then you get access.
Jun 29, 2014 | 2007 Volkswagen Golf
How to remove the rear bumper on a 2010 vaukhall insignia
if its under warranty have them install these..
Dec 27, 2013 | Cars & Trucks
Fault code P2106
is it the ecotec engine fitted 1.8 or 2.0./2.2l or the diesel 1.7 engine.. how long have you not used the air con for. not using it for a long time you can damage the pump the flown sensor. even the temperature sensor. but if the engine is trying to stall with the ac on then the pump may have a fault. ac should be run for 10min once a week no matter the weather. stops you having problems later.
Aug 04, 2013 | 2003 Vauxhall Vectra
311 cdi air-con wiring fault
Hi Muttley, Check the gas pressure in the system. The there is insufficient gas the AC will not engage, nor will the fan work. Regards John
Jul 19, 2013 | Vehicle Parts & Accessories
How to ajust the handbrake on a vauxhall insignia
How do i adjust my hand brake on a vauxhall insignia year 2010?
Dec 01, 2012 | Vauxhall Cars & Trucks
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
