Question about General Electric GE A835 Battery (Equivalent)
Turn off write protect
It has write protect can't turn it off
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • General Elec... Master
  • 102,366 Answers
I assume you're not asking about a battery? What device are you asking about?
Posted on Jul 18, 2013
My amp protection light came on one day. Now it won't turn on. What's wrong?
There is more than likely an issue with your amp, it could've happened from a wire being shorted to ground or a damaged sub causing bizarre impedance issues at your amp. Uninstal it and have it bench tested.
Jun 03, 2012 | Rockford Fosgate Power T1000-4 Amplifier
Every time I download my images to my laptop, using the laptops card reader, upon reinserting to camera I get the CHA appearing in the camera lcd topview
Try turning on the write protect before inserting the card into the card reader. This will prevent the computer from writing to the card. When you finish downloading, turn off the write protect, put the card back into the camera, and format it.
The write protect switch is on the edge of the card. The position farther from the contacts write-protects the card.
Mar 08, 2012 | Nikon D90 Digital Camera with 18-105mm...
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
My samsung avr720 reads "protection" when turned
Protect, Protection, Protector, etc. are all indicators of a problem with the output (speakers) of the device. Most times, if you're lucky - you'll find a shorted speaker wire. Other times, it can be an expensive fix. Hopefully, you shut it off right away without cranking the volume up.
Start at the rear of the unit. Make sure no individual strand of the speaker wire has touched the binding post of an adjacent speaker. Continue along each speaker wire to the binding post or termination point on each speaker. Make sure the insulation along the entire length of all the wires haven't become crushed or damaged where they pass under rugs, around corners, etc.
If you can't find a problem, you can try disconnecting all the speakers and plugging in headphones. and power on again. If the Protect message is clear, you should be able to hear the program through the headphones and have full control over the volume. This means there is stall an issue with the speaker wire(s) from the back of the unit up to and including a speaker(s).
If it still indicates Protect, the original problem continued long enough or the volume was turned up high enough to cause an internal failure of the amplifier's output transistors and will require service t restore to working order again.
I hope this helps & good luck!
Sep 13, 2011 | Samsung Audio Players & Recorders
The home theatre system LG HT904TA went in to protection mode. Mean that the receiver/dvd panel shown 'protection ' on the display panel. I have try to switch off /on but the 'protection...
If you've disconnected the speakers and the fault is still showing then the fault is internal with the Amplifier and it's shutting down to protect itself from further damage.
Your only solution is to remove the cover and have a look at repairing it yourself or take it to a repair shop.
Jun 28, 2011 | LG Audio Players & Recorders
Marantz 4220 Power Switch Dear experts Some time ago when unit switched on cracking noises in speakers started. But now exept ligting up no sound is comming just little when volume turned up.What could...
The Amplifier was failing and that's why you were getting the crackling noise.
Most receivers have an Auto Protect that shuts the system down and goes into Protect mode at the first signs of failure or overheating, usually indication by 'Protect' on the display.
I'm presuming from your post that you never got any indication that the unit was shutting down to protect itself and has just failed, so I'm presuming that this facility isn't fitted on this model.
Depending on you Technical ability it could be an easy repair (replacing the complete PCB or some PCB components). Your only other solution is a visit to a service engineer.
Jun 04, 2011 | Marantz Audio Players & Recorders
The receiver is flashing. Protect. And it want turn or program a station, what's. Wrong. With it
If it won't turn it won't do anything else.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 17, 2011 | Kenwood Audio Players & Recorders
How do I enter the Test Mode on my RISO 790 duplicator?
Do you mean into the unprotected mode?, if so
Turning OFF Protect mode in a Riso MZ 790u (and other models I'm sure).
1. Go to Admin Tab on the main console screen and scroll to the "Protect" button.
2. Select (press) the "Protect" button on the screen; printer will go through a reset function (takes about 3-5 seconds).
3. After printer is finished "resetting", pull out one of the master disposal boxes (doesn't matter which one).
4. Press the "Protect" button again.
5. the screen should say "Protect = Off"
6. You're done and your machine should be un-locked now.
May 11, 2011 | Office Equipment & Supplies
Hello, when I turn the machine something strange happens. He turns off and the message appears in the display: PROTECT. I need to turn it several times until it estabilize.Could you help me please? What...
this is common for a mismatch load at the output transistors.
I would make sure the wires aren't shorting out (could even be shorting to the building's ground somewhere in routing) or if the speaker are old and have an impedance change (rust or dried cones). the receiver is protecting it's output transistors with a relay and load testing circuit. disconnect all speakers and see if it goes into this condition with no load. if it doesn't go into protect it is your speakers or there wires. if it still does with known good speakers then you output transistors could have broken (overheated) down and will eventually fail
Jammer
May 02, 2011 | Teac Audio Players & Recorders
The system turned off because the protection system turned on, how do I turn it on?
Resolve the problem it's trying to protect itself from.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Apr 10, 2011 | Audio Players & Recorders
General Electric GE A835 Battery (Equivalent) Logo
Top General Electric Cameras Experts
Freddy
Are you a General Electric Camera Expert? Answer questions, earn points and help others
