Question about Pool & Spa
Why wont my krystal clear salt water system come on automaticaly
I have to unplug and plug in again to get it to turn on every day. why?
I dont know
Posted on Jul 18, 2013
  • 297 Answers
SOURCE: there seems to be no water preassure comming out
sounds like air lock
disconnect skimmer ( if you use one) from inside of pool
make sure the tube going from pool to pump has no debris at the motor housing
hair can build up there then trap other debris
no open you bleeder caps till water runs freely
once water is coming out and you do not hear air turn on the pump
let run for a minute then close the caps
Posted on Jul 13, 2009
thepool
  • 78 Answers
SOURCE: low water flow
Low water flow is generally and indication that the filter is dirty / clogged. Remove the filter cartridge and see if the light goes out. Replace the filter if required.
Posted on Apr 22, 2010
  • 2841 Answers
SOURCE: Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
Posted on May 30, 2010
Testimonial: "Thank you so much for taking the time and answering my question, I helped me a great deal. THANK YOU!!!!"
SOURCE: problem with system
I had the same problem with mine. It kept shutting off and we would have to unplug and plug it back in just to get it to run for not even a full cycle every day. I thought it would be a nightmare because I'm in Canada but I called Intex and within a week I received my new salt water chlorinator that works great!
Posted on Jun 18, 2010
  • 297 Answers
SOURCE: water not clear
cloudy water is mainly due to poor pool maintainence.
Your purchase of the salt water system only helped you with not needing to pour chlorine in or float tablets.
You will still need to use chemecals.
I use a good stabilizer to hold the chlorine level longer
I use a non foaming algecide once a week
I also use a water clarifying product once a week
Now on to the clouds :-)
cloudy water is because of not enough sanitizer mixwd with a crappy pump from intex
I do not know the size of your pool so I will just use mine to show you #'s
I have a 7000gl pool with a 2500gl ph pump
A pool needs to be turned over at LEAST 3 times a day so for me it takes at least 8 hours of filtering alone this does not include making chlorine.
Bottom line is you should run your system 24/7 between generating and straight filtering
The only cure for less filtering is to get a sand filter with at least a 1 horse power pump to pump 4000gl and uphaving a sand filter helps trap more small particles than the cartridge filter.
I noticed the difference the first night I had my sand filter. It ran for 6 hours before me turning my pool light on and to my surprise I did not see as many particles passing my light as with the cartridge filter and the second night nothing Crystal clear.
Bottom line is intex pumps and so on are not big enough for the pool it comes with.
The salt system alone with a sand filter is great
Posted on Jun 27, 2010
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do you reset the RCD/GFCI on Krystal Clear Salt Water System CS8100
Mine is located in the power cord, near the plug end, built into the power cord itself. If not there, then consult your owner's manual or look on the Intex website for the manual.
Jun 30, 2014 | Intex Krystal Clear Saltwater System...
Why is my intex pool water turning green even with the saltwater chlorniator
enough salt? too much salt?
running enough hours per day?
adequate flow to activate salt cell? (cf dirty filter)
Salt cell clogged with calcium deposit?
Jun 21, 2012 | Intex Krystal Clear Saltwater System...
I have an Intex Krystal Clear Saltwater System, model CS8111. My problem is green water. I had been out of town for a few days and when I came home the pool was green. Also the low salt light was on. I...
If your salt is at the correct levels required for your pool and your still getting the "91" code on your LCD screen do not add more salt you need to clean the plates on the chlorinator. Look at your manual and it gives you instructions on how to remove, clean, and replace the chlorinator section on the pump. Reminder, if your PH and/or alkalinity levels are off you'll be cleaning the plates often because of the scale build up. I personally run my pump 4 hrs daily and I have never had a problem with green water however, once it did become cloudy (white) I began treating with algaecide and changing filter every 3 hrs. It cleared it right up. I love the Krystal Clear System.
Jun 26, 2011 | Intex Automatic Salt Water System for ...
My Krystal Clear Deluxe Saltwater System Model 8110 is not turning on
My pump works, but it wont turn to chlorine, so it then turns the water green, i looked everywhere and cannot find a solution, anyone that can help that would be great.
Apr 23, 2011 | Intex Automatic Salt Water System for ...
Problem with system
There is no code 77 Call intex and give them your information. They will have a new unit shipped to you in days
They are really good with warranties as long as you have a valid receipt
Jun 17, 2010 | Intex Automatic Salt Water System for ...
I have installed my Intex Krystal Clear Saltwater system for my above ground pool and have run it for 12 hours. I want to run it another 12 hours. How do I start the system again instead of waiting on the...
First of all you should not have set it to generat chlorine until straight filtering for 24 hours. unplug then plug it back in
88 will appear let your salt disolve by filtering only for the 24 hours then proceed to generate chlorine
It may look disolve but there are many hot spots that need to get distributed eveny
Jun 07, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
