Question about Apple iMac Computers & Internet
How to unlock installation discI on the DVD/CD drive
The hard drive disc has been reformatted so no software present to facilitate ejection can this disc be removed by some built in mechanical means on the DVD/cd unit. I could not find one
    New Friend:
  • 147 Answers
Turn on your mac,when you hear the startup chime press the F12 button or the eject button on your keyboard.
Posted on Jun 05, 2014
SOURCE: My imac g4 isn't reading the dvd/cd drive at all
it won't read it because the new os disk is double layered and the g4 drive you have probably won't read double layered dvds.  best solution is to buy or borrow an usb external dvd drive.  i did this last week and it worked fine.
Posted on Mar 14, 2009
  • 166 Answers
SOURCE: A dvd is stuck in the drive. It resists all
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Posted on Oct 10, 2009
shadowqat
  • 72 Answers
SOURCE: imac intel dual core dvd drive will not mount
Installing Parallels should not change the way your optical drive works.
Try resetting the SMC as per the following article:
http://support.apple.com/kb/HT3964
If that doesn't work, try resetting the PRAM:
http://support.apple.com/kb/ht1379
If these do not resolve the issue you will likely need repair.
Posted on Aug 20, 2010
bayyagg
  • 1672 Answers
SOURCE: CD/DVD Drive won't accept new blank CDs and
The problem would be the dvd rom, it won't read anymore. That's a problem with a combo DVD rom, when it being use frequently it tends to breakdown, mainly the problem is the internal parts. I have tried repairing most DVD/CD Roms, to no avail..... mostly the problem would be the parts, and it is not available in the market, and it is better to buy a new one than getting it into the manufacturer's service center, they charge excessively like your buying a new one!
If the CD is stuck inside, get a pointed metal rod, there is a small hole in the face front and push the rod into that hole untill it opens the cd tray.
Thanks for using FixYa!
Posted on Jul 04, 2011
  • 240 Answers
SOURCE: iMAc will not eject cd discs
it may be due to virus
Posted on Aug 23, 2012
I have an acer aspire x1200-b1601a with a cd/dvd drive that will not open without putting the tip of a knife along the edge and prying it open. the "magic" pinhole is behind the case's cover and cann
CD-ROM, DVD, or other disc tray not opening Locking device or software installed First, verify no locking software installed that prevents the tray from opening. If you are unsure, reboot the computer and as it is booting up, eject the tray. If the tray can eject as it is booting, but stops working after loading your operating system, something is being loaded that is preventing the drive tray from opening. Programs used to burn CDs are a common culprit.
Bad eject button If you are running Microsoft Windows, open My computer, right-click the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective, and it is recommended that the drive be replaced.
No power to computer or disc drive If you have recently installed a new optical drive or you have moved the computer, the power cable to the CD-ROM may have become loose or disconnected. Reseat the power cable to make sure this is not the problem.
CD stuck within drive If you suspect that a CD may be stuck within the drive, the tray needs to be ejected manually. Look for the small manual eject hole that ( not the head phone jack) located on the front of the drive. Unwind a paper clip and place one end of the paper clip into the hole to eject the CD-ROM tray.
If CD-ROM tray opens part of the way, pull it gently to see if you can get it to open fully. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become damaged or dislodged. But usually, a stuck CD is blocking the way.
Caution: If you are able to open the CD-ROM drive using a paper clip, we do not recommend continuing to do so. This is meant to be used as a temporary solution; the drive should be replaced.
What to do if CD or DVD stuck in drive? Note: This document is for disc drives with a disc in the drive that prevents the tray from opening. See our CD-ROM, DVD, or other disc tray not opening document, if the tray is not opening at all or doesn't seem to be getting power.
If the CD or DVD is not set into the disc tray correctly, it could be sticking up above the surface of the tray, causing it to get stuck with then tray tries to open. In this case, it may be possible gently shake the computer and move the CD or DVD into the correct place in the tray, allowing the drive to open. However, use caution when doing this, as you do not want to shake the computer too much, or you could damage other components.
If this is a desktop computer, you can prevent damage to the computer by opening the computer and removing the disc drive in order to shake or rotate the drive. When the drive is out of the computer, you can manually release the tray by inserting a paperclip into the manual eject hole.
In the case of a laptop computer or a slot load disc drive, since the CD or DVD does not sit in a tray, it cannot be shaken in order to adjust the disc. If the disc is visible you may be able to move the disc a bit by hand, enough to allow the drive to eject the disc. Again, be careful in doing so, as you could damage the disc or drive in the process.
If you're still unable to get the disc out of the drive after following the above steps, it may be a damaged drive and should be replaced. If the disc in the drive is an important disc and you believe the drive is bad, the drive can be disassembled in order to remove the disc. In the case of a laptop or computer with a slot load disc drive, the computer needs to be serviced in order for the drive the be replaced and the disc to be removed.
reference: http://www.computerhope.com/issues/ch001487.htm
Jan 03, 2015 | Acer Computers & Internet
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
Unlock micro sd password
A cd/dvd disc named PowerSuite has the utility on board to repartition and reformat static drives, cards, and mechanical hard drives. This software disc can Boot from the CD/DVD drive when starting up the computer because it has an operating system of its own capable of staring the computer without going to the main drive. Check it out!
Dec 24, 2013 | SanDisk 2GB microSD Memory Card
My computer got a virus and now it won't do anything but let me go to f2 or f12 and that's it. is there any fix
First let's find out if your hard drive is still working.
When you hit f2, go to your CMOS settings and make sure your hard drive specs are there.
If your hdd settings are set to auto or you can see the description of your hard drive, exit CMOS and reboot your system.
You'll have to reformat and re-install your Windows Operating System, re-install your Software, and restore your data from backup.
1. Turn on your system and
2. Select f12, install your windows cd in your cd rom and let it boot from cd rom.
3. Follow the directions on your screen and allow windows to reformat your hard drive and reinstall your Operating System.
4. Once this is done, re-install your drivers from your cd or download them from the internet.
5. reinstall your software and
6. restore your data from your backups.
Note: You will get some indication if your hard drive is not visible or accessible by windows, in which case you will have to replace your hard drive. Of course this does not alwasy happen so good luck and let me know if you have any questions.
Dec 28, 2010 | Dell OptiPlex GX260 PC Desktop
Sir, Good day! How to reformat my hardrive toshiba dynabook without dvd drive
You'll need to remove your hard drive, hook it up to another computer via a USB to Hard Drive adapter and use the operating system of the other computer to reformat the hard drive. This will only reformat the hard drive, not install a new OS. To install a new OS you'll need a DVD-ROM and OS installation disc, or a flash drive with an OS installer on it to install from the flash drive.
Mar 25, 2010 | Computers & Internet
Eject does not open
Most hard-drives do *NOT* have an EJECT button.
Most diskette-drives *DO* have an EJECT buttton.
Most CD/DVD-drives *DO* have an EJECT button.
Turn your computer off. Straighten one end of a Norwegian paper-clip, and insert it into the small hole in the front-plate of the CD/DVD drive, until you feel "resistance". Then, push it another 1/4 inch, and the drive-tray should "unlock" and open slightly. Then, gently pull the tray fully-open. Remove any CD/DVD media. Then, replace the CD/DVD drive.
Jan 29, 2010 | Computers & Internet
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Dvd and cd burner problems
why can't i burn a dvd or cd on my used dvd rewritable drive the destination drive won't show my dvd burner?
Mar 17, 2009 | Philips Phillips 16X External DVD 2XRW...
I have just purchased a HP 2133 mini-note. On first installation, installation failed and now it just loops and wont do anything. How can I facilitate first installtion bearing in mind there are no disks...
The majority of these PCs have a recovery partition on the internal hard drive, here is the instructions for using it.
Recovering information using Windows Recovery Environment (WinRE)
Windows Recovery Environment (WinRE) can perform a recovery from either an optional external hard
drive or from recovery discs.
CAUTION: Using Windows Recovery Environment (WinRE) will completely erase hard drive contents
and reformat the hard drive. All files you have created and any software installed on the computer will
be permanently removed. When reformatting is complete, the recovery process will restore the operating
system, as well as the drivers, software, and utilities from the backup used for recovery.
To initiate recovery using WinRE, follow these steps:
NOTE: This process will take several minutes.
1. If possible, back up all personal files.
2. Restart the computer, and then press f8 before the Windows operating system loads.
3. Select Repair your computer.
NOTE: The "Repair your computer" option is displayed only if the WinRE partition is intact. If the
option is not displayed, refer to “Recovering information using a Windows Vista operating system
DVD (purchased separately).”
4. Follow the on-screen instructions.
5. Click Next.
6. Select your user name, type your password (if applicable), and then click OK.
7. If you are using recovery discs, insert the last disc of the recovery disc backup set.
NOTE: Inserting the last disc of the backup set confirms the presence of a valid backup. If you
insert any other disc, the backup will not be recognized.
– or –
If you are using an optional external hard drive, connect it to the computer.
8. Click Windows Complete PC Restore.
9. Follow the on-screen instructions.
this is getting long , so ill will post more steps in comment.....
Nov 20, 2008 | HP Computers & Internet
DVD/CD RAM Devices
try some 3rd party software, nero, magiciso, poweriso,,,to burn discs,,,
Or
try using XP service pack 3..
good luck.
Feb 23, 2008 | Dell (0Y435) Internal 24x CD-ROM Drive
Computers & Internet Logo
50 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
