My luxor 32-875-hdr keeps going into standby every 10 minutes or so
    Top Expert:
  • 12,223 Answers
Follow this instruction and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
my luxor 32-875-hdr keeps going into standby every - 53009844-63f4-43f3-b025-3e742bec1b5f.gif
Posted on Jul 18, 2013
Luxor model number LUX32.875.HDR wont come off standby
Could be an open internal fuse or power supply failure
Feb 19, 2018 | Luxor Televison & Video
Luxor tv loses channels each time it’s switched off or on standby.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Feb 08, 2018 | Luxor Televison & Video
When I switch my luxor TV off it keeps flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 02, 2016 | Luxor Televison & Video
Elonex tv keeps going onto standby, take about 10-15 goes to work.
Sounds like you may have some capacitors going bad. If it is a high end TV it may pay you to take it to a repair shop.
Nov 25, 2013 | Computers & Internet
Luxor tv will not power up and red light just keep flashing
I just pull out the mains plug for a few seconds then put it back in. The red light keeps flasing for a while (be patient) then stays solid red. When I then switch on again with the remote it is fine. I often have to do this.
Jul 27, 2012 | Televison & Video
Sony Camcorder Hdr Fx1 C 31 22
Here is a video explaining this problem, hope it helps.
Apr 28, 2012 | Sony HDR-FX1 Mini DV Digital Camcorder
I have bought a luxor (lux-19-822-cob) tv 22inch i have taken one exactly the same back as i had the same problem but now i have a new tv exactly the same model and size so it takes 10 minutes for the tv...
i brought a 19inch luxor telly and i only use it 4 karaoke NOT 2 have programs on ,and it kept comin up sayin shut down yes/no by remote i put no then its ok . but this kept happining so i took the telly back and got a 22inch same make a luxor first time set it up 4 karaoke and it happeded again. can any 1 help
Jan 15, 2011 | Televison & Video
My receiver keeps clicking over to standby. This now happens at least every 5 or 10 minutes. I keep powering up again but it continues to click over to STANDBY. Please help.
Not an expert on this amp But going into standby often means the system's Protection circuit is cutting in to stop an overload condition. As a quick first thing, try disconnecting all speakers and running the unit without speakers for the 10 minute period and see if that helps.
Sep 13, 2010 | Onkyo TX-SR606 Receiver
Televison & Video Logo
Top Televison & Video Experts
