Question about Frigidaire FAS256N2A Air Conditioner
Frigidaire air conditioner will not power up
Unit will not power up. Display is dead, control panel and remote does not work. Power is present at outlet and power cord. 230VAC detected at Frigidaire part number 5304476450 power board wiring blocks and terminals. Am I to assume this board is bad and needs replacement
  • Calvin Hamada Jul 18, 2013
    Somehow it listed the model other than what I listed it as the true model is FRA124HT2
  • 534 Answers
SOURCE: MY 2YEAR OLD WINDOW AIR CONDITIONER WON'T POWER ON
Apparently the gfci on the plug (the reset button) has gone bad. The best thing to do is to purchase a new cord and replace it. These switches sometimes go bad. Good Luck
Dave
Posted on Jul 28, 2009
  • 1033 Answers
SOURCE: I have a model #
Hello, i have replaced cords on many window units so yes you can replace the cord. I believe if you go to a online appiliance website they will have the cord you need. I have found this website online with frigidaire parts http://www.repairclinic.com/Shop-For-Parts?s=t-faa065P7a-==
Posted on Apr 25, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: Less than a week ago
Hello
The control panel sensor is bad.I would take the unit back asap.There should be a 1 year warranty on the unit.
Posted on Aug 01, 2011
  • 643 Answers
SOURCE: I need a need a
Sears parts direct carries parts for this unit go top this site
http://www.searspartsdirect.com/partsdirect/part-model/FAH146S2T?searchModPar=FAH146S2T&pathTaken=modelSearch&prst=0&shdMod=FAH146S2T
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Posted on Aug 28, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Frigidaire air smells bad
    Clean the front filter and any coils you can reach. Units should be cleaned every year before use. Also make sure you are not circulating air from the outside in and you are bringing in external odors.
    Posted on Aug 17, 2012
    Testimonial: "Thanks for the help. "
    The display is only showing one out of the two digit temperature setting. How can I fit it?
    window air conditioners are great for cooling a room and even to take the heat out of a house. I have done it for years now here in Florida and have central air but rarely run it like today it is about 90 and I have only one window unit running and it does a great job. When It goes out I will go to Wal-mart and spend about 150 buck and just buy a new unit, ( maybe less) get the 5000 btu if you can. What I am trying to say is don't bother fixing that unit, they are a throw away item.
    May 29, 2015 | Frigidaire FAA068P7A Air Conditioner
    Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
    Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
    Aug 09, 2008 | Kenwood KW85 Air Conditioner
    Our Kreisler air conditioner is rarely used, is 7 years old and will not switch on. The batteries have been renewed on the remote. Could it be the sensor in the unit? Do I need a service man?
    The first thing I would suggest it to verify that power is provided to the unit. You should get a display on the face of the indoor unit if there is power. If there is power, try turning the outdoor unit off for a few seconds and back on to reset the controller. If your unit is like I think it is, the indoor unit receives its power and control signal from the outdoor unit, then the remote utilizes a rf signal to control the system. Also try new batteries in YOUR remote.
    Jan 04, 2015 | Heating & Cooling
    Air conditioner unit on the wall not working, and the remnote does not turn it on, the indicator lights are not lit either.
    Please check teh power to the wall unit first, then if this is present check the remote control, check the battery. Point the remote to your phone camera and see if the camera detects the IR emission. If so the remote is working and the power supply has failed on the AC unit.
    Open to check on the main power circuit , the program controller circuit.
    Jun 17, 2011 | Heating & Cooling
    Off all winter; now won't turn on. Used remote
    Hi!!
    I am assuming that nothing comes on in the display.
    Check:
    power cord for continuity,
    power to board, if OK, replace board.
    These are the only two things I can think of that can stop compressor and fan from working.
    Don't forget to rate this answer, Good Luck!1
    Apr 18, 2010 | Frigidaire FAH085N1T Air Conditioner
    Window unit will not power up
    You need to check for voltage to the display. Just knowing the plug is working doesn't tell you that the electronics are getting power. It is possible that the power cord is bad. Once you have tested the unit and the unit is actually getting power to the display, then it's probably the control board in this unit.
    Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
    GE PTAC AZ38H09DABM2 WENT DEAD..POWER OK
    Could be the main control board.
    Could be that somebody has been messing with the dipswitches beneath the control board.
    Dec 22, 2008 | GE Zoneline Deluxe Series Cooling &...
    No Display on controller
    Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
    Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
    Fault E3
    Oct 28, 2007 | Kenwood KW85 Air Conditioner
    Frigidaire FAS256N2A Air Conditioner Logo
    Top Frigidaire Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
