Apple mac g5 power desktop dvd
I have an installation disc 1 locked in my dvd my hard disk has been wiped clean how can I release the disc physically I have removed dvd but can find no release mechanism
  • 1,606 Answers
If it is a tray-load drive, there is a small hole in the front. Pushing a straightened paper clip into this hole should unlatch the tray so you can pull it out.
Many slot load drives have the release tool entry way over on the left end of the slot. Push the straightened paper clip in there (it must go in perpendicular to the front of the drive, not angled in any other direction).
If you hit the target, you should feel something like a spring-loaded cam mechanism moving - it will take a moderately firm amount of pressure to start it, then it will unlatch and push more easily. Be careful - if the paper clip starts to bend on you, or it feels like you are bending something inside, you probably don't have the target. You should not need to apply anywhere close to the force to bend a larger-size paper clip with an end-on push.
If the computer is functioning normally, you should be able to remove the disk by starting the computer, then repeatedly pressing the eject key just before it starts the boot up cycle. To avoid having the disk pop out then pull in again while doing this (tray load), press once, pause for 3/4 second, then thereafter press twice rapidly and pause for 3/4 second. This will give you a good shot at hitting the time window between starting the optical drive and beginning boot-up and time to stop hitting eject when the disk starts coming out.
If all else fails, take the cover off of the drive (not installed or plugged in to anything) and study the mechanism. Tray loaders have a rack on one side of the tray driven by a pinion gear, either mounted directly on the tray motor or driven through a belt or gear train. You can manually turn the motor or an intermediate gear to unload the disk and run the tray out. Slot loading drives have a cage of curved bars with rollers at the edge of the disk - look for the mechanism that drives this cage and manually turn it as described for the tray load mechanism.
Do not try to pull the tray or cage directly - you'll damage the disk locking mechanism and may jam things up so the only way to get the disk out is to tear the whole thing apart. Always turn the disk load/unload motor, one of its reduction gears or belt-drive pulley (if present.
Posted on Jul 19, 2013
Testimonial: "thank you for your advice much appreciated but my optical drive is not a tray one. I have managed to eject the disc by holding down the mouse button whilst powering up computer."
  • 36 Answers
SOURCE: mac g5
 For a mac, you need to use the grey disk that came with your computer that says Disk one on it. Put it in your computer and turn the computer off. Hold down the N key and turn your computer on. It should ask you to select your language. Select it, then an installer window will come up. Ignore it. Go to the menubar at the top and select Utilities> Password Utility. Select your User account, type in a new password, and click change. you can then restart your computer and log in with your new password.
Posted on Jan 11, 2008
flyscan
SOURCE: hard disk icon disappeared from desktop
To add the hard disk icon back onto your desktop, first click the "Finder" button in the dock. It is the dark and light smily face icon at the end of the dock.
Next, click the "Finder" menu item at the top of the screen and then "Preferences". In the "Finder Preferences" window that opens, click the "General" button. From there you can select what system items appear on your desktop. You can click "Hard disks" to re-add the hard disk icon.
Posted on Oct 21, 2008
  • 55 Answers
SOURCE: Can't install Mac OS X Leopard on Power Mac G5.
email me at glenn@light.on.ca i have the fix for you
Posted on Nov 28, 2008
arnomonfort
  • 115 Answers
SOURCE: Installing OSX 10.5 on G5 Mac Desktop Locks up
try to boot on 10.4, and then introduce de 10.5 DVD. Then the computer will ask to reboot, but with good options.
Posted on Feb 04, 2009
allanster
  • 60 Answers
SOURCE: G5 Mac Desktop freezes at random
First you need to run some maintenance (which in itself may solve it) to rule out software issues, so start here...
Resolve startup issues and perform disk maintenance with Disk Utility and fsck
Mac OS X: How to start up in single-user or verbose mode
If that doesn't help, try booting into Safe Mode and see what happens, if it comes up hopefully another restart may solve, if not, you can at least use this as a starting point to try and resolve. Safe Mode will allow you to get around, surf, etc...
What is Safe Boot, Safe Mode?
Mac OS X: Starting up in Safe Mode
If Safe Mode comes up alright, I would install AppleJack, excellent troubleshooting article can be found here... Troubleshooting Tools: AppleJack
Another excellent free tool for performing maintenance is Onyx (be sure to download the right version for your system). Install the package, then run it, it will check your drive and the structure, after this, click on the automation tab and check on everything for Maintenance, Clear Cache, Cleaning, and check on Reset -> LaunchServices database and Mail's Envelope Index. When it completes, restart. Repeat any time something seems flaky, if not try to run at least once a month.
Posted on Feb 06, 2009
Flashing folder
1. You need to re-install the system software.
2. Your hard disk is dead.
Try booting with a System CD/DVD to see if you can repair the System software on the hard disk.
Jun 15, 2012 | Apple iMac G5 Desktop
Brought a company G5 mac and want to clean harddrive
If you have the MAC OS insallation CD then you can boot up with this CD then format and install the MAC OS on the hard disk.
Apr 20, 2012 | Apple Power Mac G5 Desktop
I have installed a brand new 10.5.6 on my G5 2x2 dual. After i had installed the system i configured the safety so that it would not even be possible to reboot without password from another disk or drive....
Trying booting from the Mac OS X install disc. insert the disc while holding the "option" key on the keybaord select the Mac OS X disc. once it has started select the Utilites from the menu bar from there you will see a "Reset Password.." select the hard drive select the user account enter password reenter the same password give yourself a hint to the password
at the bottom reset the "Home Folder Permissions and ACLs"
click save
reboot the same way, holding the "Option" key select the hard drive enter the password for the account you just made
once you have booted into the system go to: Apple menu (top left) > System Preferences > Startup Disk
make sure that you have your hard drive selected this makes it so after a reboot it will boot from the hard drive and not a disc.
Nov 20, 2010 | Apple Power Mac G5 Desktop
Mac G5. Grey screen with spinning wheel. This stays liek this for an hour or so. Then get desktop but just with Hard drive folder. Can open Hard driver folder but its takes about half an hour to open then...
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica}
Check for a failing hard drive
insert the Mac OS X install disc.
press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
Sep 27, 2010 | Apple Power Mac G5 Desktop
My G5 won't boot past the gray sreen with the apple logo and time wheel.
press the start button while holding down the "C" key on the keyboard
If it boots normally from the disc. you have a bad hard drive and it will need to be replaced.
Sep 07, 2010 | Apple Power Mac G5 Desktop
On power up I get a bleep then the symbol of a file alternating with a '?'. Nothing more ! Has the hard disk died ?
It sounds like the system is corrupted. What I would do is to get your instal disk to boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Sep 29, 2009 | Apple Power Mac G5 Desktop
Leopard OS
Is the hard drive SATA or IDE. On IDE, I know you can use delpart. Locate a SATA tool to wipe the partition of SATA drives. Install LEOPARD as usual then after rebooting.
Jul 25, 2009 | Apple Power Mac G5 Desktop
Disk Drive spits out brand new DVD+R DL cds
The drive in the G5 may not support DL discs. Open the system profiler (From the apple menu, select 'About This Mac' then select 'More Info'). Click on 'Disc Burning' in the left hand column. You will now get the details about the disc drive including which discs are supported.
Jan 07, 2009 | Apple Power Mac G5 Desktop
Error code when running Apple Hardware Test
Its an issue with the hard drive in the lower slot. The volume may be corrupt of the drive could be physically damaged. Did you install the bottom drive? is it the drive with the OS installed?
What does SMART statues report in DISK UTILITY?
Hard Drive/Application/Utilities/Disk Utility3a047e2.png
Let me know.
Oct 27, 2007 | Apple Power Mac G5 Desktop
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
