Question about Epson Perfection 1250 Flatbed Scanner
Connect g820a driver - Epson Perfection 1250 Flatbed Scanner
I already installed the right driver for my Wireless Adapter of my laptop but I cant connect to the internet through wireless connection. It say's their "The driver successfully installed used Fou
Did you reboot after install? What does it say when you try to connect? Why did you have to re-install the wireless adapter driver? Did you download the driver from Asus?
Jan 08, 2013 | ASUS Eee PC 1215BPU17BK 121Inch Netbook
When i connect my n2700c with pc ,they say that no drivers are installed for this device. What should i do?
all mobile phones need drivers to connect to pc.
mobile phone drivers are installed on pc so that the pc can identify the particular device upon connecting.
almost all mobile phone company issues their driver cd along with the phone.the cd might still be in the mobile pack.insert the cd and install the driver to solve ur problem.
if u dont have a driver cd,then all u need is an internet connection.
browse to any search engine(www.google.com ) and enter the keywords like this:"nokia 2700 driver download"
the search engine will show u download links for ur driver.
download it and install it.
Jul 12, 2011 | Nokia Computers & Internet
Which Scanner Driver i'm going to download if my scanner is EPSON 1250 Model G820A
You can download the driver fron this WEB site.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14548&infoType=Downloads
Jun 29, 2011 | Epson Perfection 1250 Flatbed Scanner
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
We need drivers to our Epson perfection 1250 model G820A scanner .
original drivers are always available on epson site and you can download th driver from there.
open the epson site/ select driver download option/put the model number of the scanner/ and do the free installation/
also alternately you can search the same in google.
May 09, 2010 | Epson Perfection 1250 Flatbed Scanner
Scanner epson perfection 1250 model g820a need power cable
Hi! You're looking for an ac power adapter. I'm including a link to a website where you can purchase one. Just click on the link, or if it doesn't work, copy and paste it into your browser's address window. If this helps, please rate this solution. Thanks! Hal
http://www.lcdpayless.com/productpage.php?productId=1208
Jun 11, 2009 | Epson Perfection 1250 Flatbed Scanner
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
Driver needed for panasonic nv md9000 camera
Helloooooo, I bought a panasonic nv md9000 camcorder, but didnt got drivers, now I cant connect it to My pc, from where I can get its drivers please help me!
it hasn't to connect to the pc.
Dec 24, 2008 | Panasonic NV-MD9000EN Mini DV Digital...
Want to connect motorola w230 to internet with USB
I want to connect motorola w230 mobile to internet by using usb.so how can i connect and from where i can get software(Modem driver) for that.
Jul 01, 2008 | Motorola Mobility W230 Phone US with...
Epson Perfection 1250 Flatbed Scanner Logo
24 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
