Question about Garden
John deere l130
My John Deere L130 won't steer. When I turn the steering wheel it just clicks and the wheels don't turn
    Problem Solver:
  • 17 Answers
There's a gear on the end of the steering column that's broken or the roll pin used to hold it on is sheared.
Posted on Jul 20, 2013
  • 86 Answers
SOURCE: John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
Posted on May 09, 2009
mowerman1857
  • 389 Answers
SOURCE: cant remove steering wheel from john deere rx 95
At the bottom of the steering wheel you should see a screw that goes crossways through the steering wheel and shaft. It will have a nut on one side and a phillips head on the other. Do not try to unscrew this bolt! Use a punch and tap it out from the nut side being careful not to damage the end of it. It is serated and will not turn with a phillips screwdriver. Once this is removed the steering wheel should just pull off. If it doesn't, post your model/serial number and I will check to see why.
Posted on Sep 23, 2009
SOURCE: Why would my sst18 john deere zero turn steer in
there is a servo under the main body on the right side win sitting in seat thats broken from the_w4ezv@yahoo.com
Posted on Oct 22, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
BAMOUT
  • 2478 Answers
SOURCE: john deere L130 lawn tractor
Posted on Dec 24, 2011
Where do u place the attachment lift lever on a john deere L130 r where can i find a diahgram for it
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMGX21647.../OMGX21647_K35.html
Picture Note: Console on Models L120 and L130. A - Throttle ... Put attachment lift lever (A) into the slot adjacent to desired cutting height. · Slide the height ..
Aug 18, 2015 | John Deere Garden
I have a John Derre L130 and the left steering arm has lots of play any suggestions?
it has a steering wheel not steer arms... your issue is either something is bent/broken, the steering shaft is stripped or the steering wheel is just off
Aug 29, 2014 | John Deere Garden
John deere l130
Most are not adjustable, however I have heard of replacing the bushings on the knuckle, however if it is worst than that, it is possible to heat and bend the spindle. However you do take the chance if damaging it.
Aug 24, 2014 | Garden
My L130 will not turn right.
you will need to change the steering gear , and the steering pinion and its not a bad idea to change the gear pivots (2) and also the bottom steering wheel shaft bushing. they sell a complete kit on ebay that has it all in one nice n tidy kit.> http://www.ebay.com/itm/JOHN-DEERE-STEERING-GEAR-REPAIR-KIT-102-135-LA120-LA155-/261112192757?pt=LH_DefaultDomain_0&hash=item3ccb7fdef5
dont let the high price full you, just the pinion $40 and the steering gear $32 is $72 and you get both and the $10 bushings x2 plus for the same price!!
Apr 24, 2012 | John Deere 22HP VTwin 48" Riding Mower
How do you adjust the steering toe on a L130 lawn mower?
The L130 off of the show room floor does not have adjustable drak link / tie rods.
One of the 300 hour inspections is to inspect the steering pivot bushings. You jack up the front from the center and check for play of the pivot bushings by teetering the tie at the 6 and 12 oclock positions. If you get a lot of movement the bushings are bad. If the bushings are ok (I doubt they are) then you can also add adjustable tie rods
1 GY20492 ROD, RH DRAGLINK ASSY. ADJUSTABLE
1 GY20491 ROD, LH DRAGLINK ASSY, ADJUSTABLE
http://cgi.ebay.com/John-Deere-Tie-Rod-Drag-Link-L110-l120-L130-L-Series-/280669312038
They are more expensive at JD ($66.00)
Just note the pivot bushings do NOT show up on any JD diagram but they do exist. Check with JD parts. They most likely know the PN from memory.
http://jdpc.deere.com/pimages/MP29/MP29762________UN16SEP02.gif
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | John Deere 22HP VTwin 48" Riding Mower
How to change the Belt on a John Deere L130 with 48" mower deck? Is there a Belt diagragm that show proper routing?
Try the John Deere parts website https://jdparts.deere.com or give sullivans a call they are a john deere dealer and are garden machinery experts they will be able to explain to you what to do. you can find their contact info on their website http://www.sullivansgardenmachinery.co.uk
Sep 18, 2010 | John Deere Garden
Garden Logo
234 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
