Question about Fisher and Paykel DE60FA-US Dryer
Won't come on.
Sunday morning my electricity went out in my house and woke me and the kids up. I heard a click in the area of my dryer. I later set the dryer dial and pressed Start and nothing happened. However the Signal light was lit up. I opened the front door and the inside light did not come on. What could be wrong with it?
    New Friend:
  • 4 Answers
Sounds like there may be wiring problems where your dryer connects, causing your breakers to trip. I'm no expert but that's definently my first guess
Posted on Jul 18, 2013
Testimonial: "I had the breakers checked and none were tripped. I had someone look at my dryer and he suggests the Timer could be bad and/or the control might be bad. He thinks the EOC Board is okay. "
Good evening all, This morning woke up to my home
Sounds like a faulty Tstat that's sending a low voltage signal to the contactor coil only sometimes. The high pressure cut out or the compressor's internal thermal protection could of opened, and then closed again after cooling. Make sure the condenser is clean and not obstructed.
Aug 31, 2013 | Whirlwind FH-778 Air Conditioner
LG2701V stopped working after lint trap was not in place
Pull the dry out and clean (UNPLUG IT FIRST) out the entire exhaust vent system..
Sep 20, 2017 | LG DLE2701 Electric Dryer
Working fine this morn went to use again wont start
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 19, 2010 | Whirlpool LER4634J Electric Dryer
Dryer is heating but clothes are not drying.
Judging by the increasing moisture, your dryer vent is not venting the moisture to the outside. Check your vent pipe for blockages. I had a person a while back with a similar problem, and this person had a lint trap on the connection that went to the exterior of their house, so check that out as well.
May 08, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Engine dies while driving.
the noise you heard in the rear was the electric fuel pump working but it sounds like you have an electrical issue check your wire harness for areas that wires chaffed on metal and cause break in the electric current some known areas are inbetween the radiator and the transmission down towards the tranny pan also check fuse panel might have a loose fuse
Jul 02, 2009 | 2001 Dodge Neon
Install 220 outlet for electric dryer or trade it for gas dryer?
Thanks for all the input!  We reached a compromise in hiring an electrician who was willing to come out today and install the connection for half what everyone else quoted...on a Sunday!  The laundry piling up in the corner was very persuasive in convincing us that your advice (in the end, we'd need a professional no matter which way we went) was prudent.  Thanks. jersey p
Sep 13, 2008 | Kenmore 63942 Dryer
Whirlpool dryer runs but does not heat
the problem could be the wiring in the house. the dryer not only needs 220v but also a good ground/neutral. this is a common misunderstanding when people test their outlets with a meter. this is happening too frequently to be a problem with the dryer(s)
9bed73e.jpg pic borrowed from fixitnow.com
Aug 02, 2008 | Whirlpool LER5636P Electric Dryer
Dryer stays hot hours after using it
The heater has failed and/or is shorting to the case. Remove the rear panel. The heater is on the right side, attached to the heater housing with two screws.
Jun 25, 2008 | Kenmore 62802 Electric Dryer
Not working at all
reset your circuit breaker - if it pops again, check for a blown element or burned out motor
Feb 09, 2008 | Kenmore 62602 Electric Dryer
Fisher and Paykel DE60FA-US Dryer Logo
133 people viewed this question
Top Fisher and Paykel Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
