Question about Directv Televison & Video
Skipping Issues with DirecTV DVR
Sometimes my DVR skips (audio and picture) during live TV. It usually starts out very sporadic and then increases in frequency. The only solution that I've found is to completely power down the DVR, wait a few seconds, then power it up. The DVR then runs diagnostics and then works fine for a few months before I have to repeat the power down process. Any ideas on what's causing this?
  • 308 Answers
SOURCE: DirecTV DVR Shuts Down and Re-boots Without Warning
With the DVR up and operating well I would lift up one corner about 1/2 inch and drop it to see if that causes it to malfunction. If it does, then you likely have one or more bad solder connections inside that need repair. If no change is noted, then it could possibly be defective capacitors or a voltage regulator going bad on you. There is also a possibility that it could be a worn recepticle the unit is plugged into, as a power interruption may be all it needs to reboot.
Posted on Dec 29, 2006
  • 27 Answers
SOURCE: programming the directv remote to program a sony audio receiver
Go through the process of setting up the remote again instead of trying the volume first use the power off button. In my experience, Sony receivers can be picky and power cycling "will" insure the code set, then try the volume.
Posted on Mar 09, 2007
  • 40 Answers
SOURCE: Motorola DVR headphone problem.
are you connecting the headphones to the tv or cable box. Also is there any home theater systems being used in this setup
Posted on Apr 05, 2007
  • 86 Answers
SOURCE: Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Posted on Jan 22, 2008
SOURCE: Direct TV/Olevia 247 audio skipping
I have the same problem with comcast HD, completly useless talking to them, they do nothing to assist
Posted on Jul 01, 2008
ViP612 DVR-HD poor play back of recording
kmej350,
Thank you for bringing that to someone's attention as I would love to help you with it! If you need the receiver replaced, you can feel free to email me your account number so I can see about getting a replacement shipped to you! My email address is michael.lemar@dish.com and I'll look forward to the opportunity of getting this taken care of for you so you can start to enjoy your programming!
Dec 18, 2012 | Televison & Video
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Same thing..skipping while playing
Open the card door and hit the reset button. Happened to me and the reset fixed it.
good luck
Oct 06, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Audio/Video problems
Do you have any codec packs installed?
If so uninstall them and install these two.
http://sourceforge.net/projects/ffdshow
http://ac3filter.net/project/1/releases
Most popular media player
http://www.videolan.org/vlc/
Apr 24, 2009 | Gateway MX6436 Notebook
Dish DVR problems
if the show that you are recording is also skipping on live tv, then it could be 2 things. it could either be a broadcasting issue (which the broadcasting center at dish network would have to correct on their end) or 2. it could be that your dish needs realigned. also if you purchased the dish dvr through dish network their models are quite often refurbished where they fix old models and send them back out. (most satellite companies do this) contact dish network and let them know you are having a problem, they may replace your dvr and if you have a protection plan they will often replace it for free.
Apr 08, 2009 | Televison & Video
I have a samsung pn50a450 plasma tv. The top of the tv has "dancing?" pixels. I have a directv r15 dvr using s-vid out to a harmon kardon avr345 upconverting to hdmi out to the tv. I have...
I have the same set, SD satellite going into S-Video. Some channels on S-Video, as well as digital broadcast over the air, have noise at the top, in my case it looks like 'dancing' white line(s) With 'just scan' it is visible but if I do "4:3" or whatever the native aspect ratio is with the "p.size" button on the remote it goes away. Hope this helps. You might skipping the HK and go right into the S-video as an experiment. I have been reading that this set sometimes does not size properly with certain brands/types of equipment.
Apr 02, 2008 | Samsung Televison & Video
Mar 26, 2008 | Televison & Video
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
DirectTV Dvr Playback of Recording skipping and locking up reciever forcing Resetof reciever.
Have either of your tried unhooking the HDMI connector if you are using it and try component?
What software are you running on the unit. The HR20-700 and HR20-100 just got a software update that was going to fix this problem w/ the unplayable recordings.
stephnt:
If it is erasing your content that is a good sign of a defective hard drive. These units when they boot up (after a software update) check the hard drive. If they run into a problem (bad sector) they will foolishly erase the hard drive, thus erasing everything you have recorded. If this is your 4th unit, you may want to look at your environment as well (well ventilated, good connections, etc) I'm not saying it couldn't be the unit. It took directv 14 units to get 3 working, and since I've had 2 HR20-700 refurbs that were unstable and were quickly replaced.
It might be in your best interest to invest in an external drive solution for the HR20. I, however, would be calling customer retention and having a calm, but stern chat with them about this.
Nov 16, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Televison & Video Logo
61 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
