Question about PANDIGITAL SuperNova
Pandigital wont turn on
I have it plugged in will not come on have a green light showing its hooked to charger but nothing else will work
showing its hooked to chargr but nothing else works.
Posted on Jul 29, 2013
My supernova will not come on at all
Plug in either the standard charger or a micro USB charger, the screen should light up. If it does not.... Repair is needed!
Jul 05, 2014 | PANDIGITAL SuperNova
Nexus 7 wont turn on
It could be the battery, have you tried another charger? Perhaps a more powerful charger? If not take to a reputable repair shop
Apr 19, 2014 | Tablets & eReaders
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
How do i unfreeze my android tablet
My Pandigital screen is frozen, all I get is a green android with a triangle with an explanation mark inside it. How do I reset this?
Oct 28, 2012 | PANDIGITAL SuperNova
I HAVE A PANDIGITALSTAR ANDROID TABLET WHEN I TURN IT ON IT STAYS ON THE WHITE SCREEN AND SAYS PANDIGITAL WITH THE BLUE DESIGN BUT I HAVE NO ICONS AND WHEN I PRESS THE BUTTONS AT THE BOTTOM NOTHING HAPPENS...
had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
Dec 15, 2011 | PANDIGITAL Digital Book 843967071153...
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
My Toshiba Portege M200 just stopped charging and wont even turn on? Is this the battery? Or what? The charger will be plugged in the wall and plugged in the laptop but nothing?
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
Mar 22, 2011 | Toshiba Portege M200 Tablet PC
Pandigital novel 7" WHITE ereader wont turn on.
You can try pressing the reset button with a straightened paperclip of pin. If that doesn't do anything removing the back and unplug the battery. Leave it unplugged for a minute or two and reconnect it. Be careful unplugging it as you don't want to put to much force on the wires. You can use a small screw driver or tweezers to pry on the plug. The white plug here is what you're locking for. See if it powers on and hopefully it does. If not you may have to contact Pandigital.
Hope this helps
Ray
Mar 12, 2011 | PANDIGITAL Digital Book 843967071153...
PANDIGITAL SuperNova Logo
169 people viewed this question
Top PANDIGITAL Tablets & eReaders Experts
Colin Stickland
Colin Stickland
castletech
castletech
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
