I have a 2009 Sonata with nav system. During the day I noticed that the screen is bright white and green backgrounds...however, at night the colors become gray and dark green.I thought something was screwed-up.
Service tech says it works with headlight day/night sensor. But, he didn't sound too sure. Anybody else notice this?
Turn the display brightness knob (the one up by the speedometer) down. When the brightness knob is at max the navi will not go into night mode. This information is in the manual buried somewhere.
I have experienced many electical demons with all my British cars. The nav units can and do fail. I had a goofy one this summer and the only way it got fixed was to replace it. The module not the head unit
I know this is an old thread, but my 2006 325i Nav screen went bank also, but the radio still played. I noticed the glove box light and trunk light did not turn on also. I was told from mechanics is was probably a CID module for $2200, even though I mentioned the glove box and trunk light light were out and specifically inquired about a fuse. The mechanics never checked the fuses, because I checked my fuses in the glove box and found the fuse 61 marked with a BMW symbol that looks like light bulb was blown. The Nav screen started back up once the fuse was changed.
No solution, same problem, but had many strange moments: 4 months ago during 100 kms or so it stopped, then suddenly came back, and worked ever since. A few days ago, it started happening again: NAV stuck, then radio dead, and gradually the rest disappeared. I did a Reset, and since that moment I see the intro-screen and then it goes black. Hitting the TEL button is somehow also a Reset...
Do the previous 2 posters have anything to report on this matter? It would be VERY welcome!
My problem with the NAV system zooming in and out all by itself was fixed by the dealer. It seems there was an electrical short in the controller knob (the round knob you use to navigate the screen with). They had my car for two days, running it now and then, waiting for the problem to occur. It finally did, and then they replaced the controller knob. It has been working fine ever since.
Installing the DVD Map Disc
Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
Press (power) to turn the navigation system on.
Press the NAV hard key.
Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
Load the map DVD partway into the slot. The system pulls it in.
The screen cannot be closed until a double beep is heard. Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc
The navigation portion of the system cannot be used if the DVD map disc is not loaded.
Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
Touch the Map Database Information screen button.
Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out.
Thanks for the reply. Sounds like a good answer.
Still can't believe Hyundai thought of that, too!
