Vivanco tvf25 how do i set the ariel to the tv to get a picture
    Top Expert:
  • 12,223 Answers
Follow this instruction. God bless you
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual)
Posted on Jul 19, 2013
I have a Lenco KDV-309 flipscreen. problem is reception, I am using an outdoor aeriel which I previously used on another set in the same room. however I now have an problem with reception in that the
Change the position of both the set and Ariel and try. If the room is at the ground floor of any building, signal strength will be very low, can cause unstable and grainy picture. Change the position of the Ariel and check. http://electronicshelponline.blogspot.com/
Nov 25, 2014 | Televison & Video
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
When you turn on power nothing comes on
It could be one of a couple of problems really, the first one may be that your analogue signal is being switched over to digital which is happening across the UK at the moment, buying a digital receiver would resolve this straight away. It could be a problem with the ariel connection to the TV, check that its all pushed in properly at the back of the TV. Failing this then its a problem with the TV set, the fact that the set produces a picture on other sources (dvd) implies that if it is a fault with the TV its with the ariel connection.
do vote if it helps you :)
Mar 31, 2011 | Televison & Video
Need to program vivanco remote control ur30. i dont have codes
Hello
To which device do you want the codes from Vivanco universal remote control?. You haven't specified it in your post. Please clearly state, the model number and brand name of the device you want to synchronize with Vivanco universal remote control by Fixya. OK.
Mar 12, 2011 | Audio Players & Recorders
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
Codes for universal tv remote control vivanco upr 250
Try here:
http://www.vivanco.de/cgi-bin/vivanco/en_US/productList.html
Sep 30, 2008 | Televison & Video
Sound
First I would check the cable from the ariel to the tv and all connections in between.
May 15, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
