Question about KitchenAid KGRA806PSS Gas Kitchen Range
No display?? Easy fix?
Oven is working, beeps, heats, etc...just no display. Noticed the digital read out would dim and brighten during use over last few months.
    Top Expert:
  • KitchenAid Master
  • 12,223 Answers
Please see the diagram attached. see if plug or connector is loose, or bad contacts. clean it. Otherwise you must replace the complete display.
God bless youNo display?? Easy fix? - a3a2240f-86a0-4feb-a216-be1818cee541.gif
Posted on Jul 18, 2013
Testimonial: "Thanks! I will try this."
2 Suggested Answers
  • 104 Answers
SOURCE: My Kitchen Aid Supuerba top
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Posted on Oct 04, 2008
The display is dim on the oven. Everything works
1. Sometimes you can clean it inside to brighten it up for a while.
2. In some cases, we can replace the VFD to brighten one up if it's available for a given model.
3. The last solution is to replace the control circuit board.
For more specifics on the options 2 & 3, we would need your brand and full model number.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well as your symptoms, "dim display".
As for suggestion # 1, cleaning:
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Dec 13, 2009 | Jenn-Air JMC7000 Microwave Oven
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Oven digital display not working well
I got your fix no prob. This is going to cost you a buck fifty, that's $1.50, I say it again...one dollar and fifty cents! Got your attention yet?
Here's the solution to a dim display or non working display when the oven otherwise works.
1. Turn off your circut breakers to your oven, then remove the display and control panel via the screws you see on the top or underneith. There will be about 4-7 screws based on your model oven. You'll pull it either up or down depending on the model by grabbing with both hands on either side of the panal after you have removed the screws. 2. Carfully remove the three or four ribbon cables connecting the display panal to the oven electrically. This should be done carfully and only after the power is shut off to your ovens by the circut breaker or unplugging them. 3. Pull the display panel out by unlatching the black plastic snap holders. Using a soldering iron (costs about 15 bucks at radio shack), remove the C3 (68uF 35V) capacitor from the board. Replace it with the 100uF 35V capacitor from radio shack or digikey for $1.50 +tax. If you don't know how to solder, well you can learn for about 15 minutes of your time, or you'll have to resort to paying your repair man over 300 bucks to fix it himself and the best part. HE CAN'T SOLDER EITHER! He'll replace the whole display LCD because that's the most profitable choice for him and Jenn-Air/Matag. 4. After getting upset at how easy this fix was, put the oven together and rejoice that you just fixed your display problem for less then 2 dollars and about and hour of your time considering the search the brought you here. Cheers to you and to me for letting you know about this. Share all the knowledge you have with others. It's free money!
Apr 23, 2009 | Jenn-Air Ovens
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Clock display board
Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
I hope this helps.
Apr 11, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Dim Panel Lites
Only fix is to replace display board. This may be a seperate board, but often is part of the range control board.
Nov 22, 2007 | Kitchen Ranges
Display is extremely dim to where you almost can't read it anymore
take down the display and clean the contacts if that does not work replace it.good luck.
Apr 27, 2007 | Sharp R-360E Microwave Oven
KitchenAid KGRA806PSS Gas Kitchen Range Logo
101 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
