Question about Singer 14SH654 4/3 Thread Stitch Sewing Serger
Stitches My stitches are too loose. You can even see the stitches on the front of the material. I can't seem to be able to adjust and get them right by using the manual. Please help!
  • Singer Master
  • 7,365 Answers
If the tension dial don't make the stitch better, then the machine needs to be checked to see if tension dial need adjustment or there is a timing problem
Posted on Oct 13, 2013
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
There doesn't seem to be a stitch long enough on machine for basteing so I can gather material?
Try loosening both top and bottom tension. while longer stitches are easier, it can be done on shorter stitches as well. A bennifit to shorter stitches is the gathers will be smaller and easier to work with! Remember to reset the bobbin tension before sewing again.
Dec 16, 2012 | Janome 8080 Computerized Sewing Machine
Bottom stitch too loose
try adjusting the top thread tension one number or letter higher at
a time till the stitches look correct
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
also check the bobbin to see if it's warped
Jun 07, 2012 | Sewing Machines
I have the Mega Quilter and Quilters Cruise Control. My stitches are very inconsistent.
I agree to have the regulator check, & even having the whole machine checked wouldn't hurt.
May 15, 2012 | Sewing Machines
What causes the bottom stitch to look like it's catching the material when I sew?
try changing the needle--flat side to the back of the machine
the needle & thread & fabric have to be compatable
light weight fabric requires a different needle than medium to heavy weight fabric
if you do not have a manual check with bernina customer service about one
or
sewing partsonline.com
try a top tension of 3 or 4
clean under the needle plate & in the bobbin area for loose thread or lint
Mar 30, 2012 | Bernina Artista 180
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Simplicity Fashion Pro Sewing machine problems. Machine stitches are too loose on the bottom of fabric.
try setting the top tension to 4 or 5 & see if the machine sews any better, you should see a nob or dial with numbers or alphetbet letters on it, that's normally on the left side of the machine
also try changing the needle, it's possible that it's bent or blunt
also clean under the needle plate & in the bobbin area for loose threads & lint
Jan 28, 2012 | Sewing Machines
Distorted embroidery with Designer SE
have you tried changing the needle
try rethreading the machine top & bottom
also clean under needle plate area & bobbin area for loose threads & lint
Jan 27, 2012 | Husqvarna Designer I
Skipped stitches. Also, won't transition
have you checked the needle to make sure it's in correctly--flat side of needle goes to the back of the machine
correct needle insertion is mandatory for the proper use in your sewing machine. Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
place the new needle in the needle clamp with the flat side of the needle facing the back (or if using a round needle the groove in the needle should be facing away from the shaft.
push the needle all the way up to the stop, or as far as it will go, then tighten the needle clamp screw.
how to decide which needle is correct to sew with, it depends on the fabric & thread being used for the project.
like for example, I've been sewing for over 30 years, I'm sewing a stretchy fabric & regular needles won't work because they skip stitches & will pull the fabric thus damaging the fabric, the needle I have to use is a singer universal ball point needles, & I have no problem with the stitches they come out fine.
Sep 10, 2011 | Brother XL-2600
Singer Futura 250E - thread is shredding after 5-6 stitches
no damage to the machine yet
check the thread size you are using as you may have to use a needle with a bigger eye
thread is made by winding the material around and around then using a product to hold the material ends together
as a result thread will not last indefinitely and will break easily
you may have to use only thread from manufacturers that you know make good thread
Apr 03, 2017 | Singer CE-200 Quantum Futura Computerized...
Singer 14SH654 4/3 Thread Stitch Sewing Serger Logo
98 people viewed this question
Top Singer Crafts & Hobbies Experts
Shelagh Howe
ray gallant
R.A. Ellis
R.A. Ellis
Are you a Singer Craft and Hobby Expert? Answer questions, earn points and help others
