Question about Emerson Quiet Kool 18HT43 Air Conditioner
Emerson model 18ht43 ac unit was stored for a year.worked good when put in storage now nothing comes on fan or a/c any ideas.seems to have power on both sides of switch and t/stat and solenoid has good continuity
3 Suggested Answers
SOURCE: emerson quiet cool
a real hummer. humm can be the sound of a short.but it sounds since u did only turn the fan on it hummed ...fanns are blower motors in acs the motor I bet ate it and needs a new one no way of fixing the motor but most are easy and cheap to replace...go or call an ac applance man ...see if he got a good used one for you or go the manufacture take model make serial no. sometimes u can spin the fan while on and it takes off again...this is dangerous so use a plastic long something but will dy again after u turn it off. good luck. CrazyLarry
Posted on Jun 30, 2007
  • 79 Answers
SOURCE: Heat/AC unit in working order, plugged in 20Amp outlet.. no fan?
Hi1
Do you have at least 200 volts at your outlet? Check that first. You said you brought it home from work, so when you plugged it in at home did you plug it into a 120 volt recepticle?
Posted on Jan 01, 2010
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
Sub zero 736 condenser fan not running
You will need to remove the cover around the condenser fan motor then remove the screws holding it down to the base. Remove the wiring from the junction box and away you go. Do not run the unit without a working condenser fan motor, you run the chance of causing yourself many other problems. With a new fan motor the unit should run fine unless there is waxing in the cap tube from overheating. Good luck
Sep 08, 2012 | Sub-Zero Refrigerators
Hi1
Jan 01, 2010 | Emerson Quiet Kool 12NW46HK Air...
An Emerson T series 6volt,200AH,battery stored for
11% loss over 2wo years sounds pretty good to me. What is the electrolytic source? If it is NiCad, maybe not, but anything else should be fine.
Oct 21, 2009 | Emerson Fans Emerson SW102 White Battery...
I have a GE small unit that is 5 to 6 years will not start up
About the only thing can suggest is see if a lamp or other will work in the outlet that you have the AC unit plugged into.
May 07, 2009 | GE AJCQ08ACB Air Conditioner
Lights come on but nothing shows its black.lens looks good
I have seen a few of this model and the tubes were gone in each case. Best way is to check if HV present at tube - get someone who knows what they are doing to take a look. If it is the tube, it will be expensive to repair. Unscrewing the lens may reveal that the inner surface of the tube has dark marks, also indicating possible tube damage.
Nov 13, 2008 | Famous Trails Calypso FT700 Monocular
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Emerson quiet cool
Jun 30, 2007 | Emerson Quiet Kool 10MW42K Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
