Question about Dorman 2000 Chevrolet Blazer Switch / Front Axle 4WD Switch
2000 chevy blazer 4wd stumble stall on start and idle
Ran beautiful til I had some work done went home with problem afterward stuble stall on start, run great until idle at a light, hesitate/miss on acceleration then recovers. Checked plugs and wires. Not setting off the engine check light. My sense was the mechanic created the problem, something simple, but wanted to make another 500 to fix it. No drips or leaks, no other indications of anything wrong. Tried dry gas treatment some inorovement on running but not the stumbles.
  • Amanda Budnick Jul 18, 2013
    have to start it over three times then it stats and runs fine til idle, if I keep my foot on the gas and the brake it does not hesitate after idle.
  • 4 Answers
Its not The mechanics fault all the time, you may fix something then something else goes wrong thats mechanics 101. I've had this problem before I replaced my ignition coil and my fuel pump, fixed it right up in my 96 f150. Give it a try its a whole lot cheaper than most options.
Posted on Jul 18, 2013
Testimonial: "heres what I gathered online about the 2000 Chevy problem: there are 15 reasons under a 100 bucks why it could happen, and one of them is the ground wire getting slightly loosened during a water pump replace ment-guess what was rerplacedwhen this started?? Yep. And the mechanic should know this. As far as the car having this problem there is a plethora of complaints all of which run like this...the mechanic said irt was the fuel pump, which ai replaced and its still happeneing. 1100 dollar repairs should never happen until all of the smaller possibilities are eliminated. And just because you are a mechanic doesnt mean you are entitiled to large amnmounts of money from people just because they brought their car to you. "
The aluminum pot that goes in my rice cooker has started leaking after 16-18 years. Is there any fix? Is it trash. I doubt I can find a replacement pot. Thanks for your time.
i cannot think of any repair, that would work on thin aluminium and be safe for food preparation. (not that i would eat from afterwards anyway).
if it leaks, it is almost certainly too thin to weld.
i would not trust soldering/brazing with the heat.
chemical sealers/glues are not suitable for food prep items.
i am sorry, but i think it has cooked its last meal
Feb 28, 2011 | Vacuums
How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
Feb 16, 2010 | Simplicity Vacuums
My bissell easy vac won't pick up after first use
Well after reading and re-reading my bissell easy vac manual (I had only used the vac twice), I went through all the troubleshooting recommendations. I cleaned out all filters and even though I had only used my hose attachment once, I was shocked that it was completely clogged! I took the whole thing apart and thoroughly cleaned it out according to the manufacturers instructions. It is working beautifully again now, I just take extra care to check it after every use...it can be a hassle, but I find that's what happens when you buy bargain items; you spend less but end up investing more time in upkeep. I hope this helps!! :)
Dec 20, 2008 | Bissell 3102-0 EasyVac Upright Vacuum
Hoover F5906-900 motor sounds very loud.
Bearings in the motor are bad, you will have to replace the motor.
Nov 09, 2007 | Hoover F5906-900 Upright Steam Vacuum
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
May 29, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Dorman 2000 Chevrolet Blazer Switch / Front Axle 4WD Switch Logo
Top Dorman Vacuums Experts
JoeVacs
Are you a Dorman Vacuum Expert? Answer questions, earn points and help others
