Question about Kitchen Ranges
JDS9860AAP Front e-burner does not light.
I have a jds9860aap with two issues. 1. The front e-burner does not light. I took the burner out and using a lighter the back feed tube burns like a torch but the front will not light at all. Any ideas? 2. The back right burner will not spark but it can be lit manually. The front sparker is working correctly.
    Top Expert:
  • Kitchen Ranges Master
  • 12,223 Answers
Follow this instructions. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Posted on Jul 18, 2013
SOURCE: jenn-air manual
i have a jenn-air, SVE47600B, when you put power to the unit, the broiler element comes on and stays on. In the past, someone pried the door open, during a clean cycle. Than the unit would shut off in the middle of baking or broiling, so they called a service guy who took the wiring diagram when he left, he also unwired the door latch used during cleaning cycles. He told customer it needed a new control panel, the guy did not do the repair, he just unplugged the broiling element and used the stove top. So now i reattacted the door latch switch and hooked up the broiler element , then turned on power to the stove and sure enough the broiler came on and stayed on. with no wiring diagram and rusty skills i am looking for advice and help and maybe a wiring diagram. Went to sears web site and they have a control panel or a relay board(down draft), relay board (bake/broil).....pricing between 200-300$ each and i dont want to just throw money at it......HELP
Posted on Feb 15, 2008
  • 3 Answers
SOURCE: Older 6 burner wolf commercial range ignition problem.
If it were the gas regulator, existing flames would go down as more burners are turned on.
There are set screws on the pilot fittings that come out of the manifold, you could try turning those Counter-clockwise to turn the pilots up. (Don't loosen them all the way, they will fall out!) If that doesn't work chances are the pilot stems will have to be replaced to get a higher pilot flame.
Posted on Mar 12, 2008
  • 42 Answers
SOURCE: I have a Viking 4
you have a faulty spark module submit your model and i will post your part #
Posted on Dec 21, 2008
danromarris
  • 101 Answers
SOURCE: One burner will not spark for ignition.
The spark mod. needs to be replaced again. Check and make sure that the wires are connected to it good though and that they have a good connection. If all looks well though you will most likely need to replace that spark mod. again. Let me know if you have any other questions and if this was helpful. Good luck.
Posted on Jan 22, 2009
SOURCE: Oven Burners not lighting completely
It's the igniters. They increase in resistance as the elements age and decreases the current required to heat the spring element in the gas valve.
Replace both igniters.
Posted on Nov 29, 2009
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn-air elecrtic oven JDS9860AAP is slow to heat up and will not come up to temp.
Either you have an open element a burnt terminal lead or a bad control try setting on broil only the element should glow in bake the bottom element should glow while the top cycles on/off based on your description of a humming noise I would suspect the relay on the control board
Feb 16, 2015 | Jenn-Air Kitchen Ranges
Automatic fan
THIER IS MISSING A SEPERATOR THAT WILL STOP SUCKING FROM UNDER AND WILL TAKE TOP AIR
Nov 16, 2013 | Kitchen Ranges
Jenn-air dual fuel jds9860aap intermitently display blinks like it lost power, reset and it will happen again. originally started with a f9 code that has not reoccured. If the oven is on, it will shut off...
Sounds as if you have a bad ground or nuetral wire connection. Unplug and check the connections to your control assembly and the pigtail on the range. I have also seen displays on Jenn-air go bad as well.Replace the clock assembly.
Apr 19, 2011 | Jenn-Air JDS9860A Dual Fuel (Electric and...
I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Apr 11, 2009 | GE Kitchen Ranges
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Jenn-Air JDS9860AAP Control Panel Problem
Control Panel
1. Remove power from unit.
2. Remove burner switch control knobs.
3. Open oven door and remove screws securing control
panel.
4. Remove screws located on the right and left sides of
the control panel.
5. Grasp control panel on the far left and right sides and
gently pull the control panel out and down.
NOTE: Gently pull control panel out and down.
6. Remove infinite switch control knobs, infinite
switches, indicator lights, rocker switches, and
electronic control/clock (as necessary) and transfer to
the new control panel.
7. Reverse procedure to reinstall control panel.
Electronic Control
1. Remove control panel, see “Control Panel”
procedure, steps 1 through 5.
2. Remove screws securing electronic control bracket to
control panel.
3. Label and disconnect terminal wiring from electronic
control.
4. Reverse procedure to reinstall electronic control.try that
Jan 16, 2008 | Ovens
Will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Dec 01, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Kitchen Ranges Logo
101 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
