Question about Garmin GPS 152 - GPS receiver - marine Antenna
Display very unclear
I think that moisture has got into the unit via the front screen. It works but the display is broken up and very difficult to read.
    New Friend:
I have a TomTom Go 520 when I attempt to put password in only numbers 7&8 light up I've tried reseting it whats the problem
Posted on Jul 19, 2013
My air conditioner showing on the display is E1
The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
How to Fix an Air Conditioner When It Gives You an E1 Code eHow
Jan 24, 2016 | Heating & Cooling
The LCD display screen is cloudy on one side so difficult to read part of display. Is there a way we can remove it and clean the glass?
I don't have your model number to look up but I'll try to answer. Most digital displays have 2 parts to the display cover. The actual display and sometimes a clear or green plastic cover to help protect the actual display. That type system can usually be removed and cleaned. Some of the newer systems have eliminated the extra cover, so if moisture is getting behind the display you can't clean it. If it is actually moisture, applying heat from a hair dryer may help get rid of some of it but be careful you don't get it too hot and melt the display.
May 13, 2015 | Electrolux WaveTouch Perfect Steam 8.0 cu....
Can a screen be replaced on a hannspree 10.1 tablet?
I replaced a broken display screen on an iPhone4. I ordered the
screen/digitalizer from Amazon for 16 bucks and it came with a number of tiny tools for the equally tiny screws and fittings.. It took me three hours of tedious labor to get it apart, to connect the screen/digitalizer (some wires with multi-connectors on the ends that are attached to the display) and put it back together. I used 15, numbered cupcake pan, paper liners to keep all the tiny parts in their proper places. I downloaded 25 pages of instructions from the Internet and printed it out as a repair manual. Bottom line, it worked and still works like new.
If you can find a screen/digitalizer for you device by Googling it and if you are handy with small items repair give it a go. But, be sure NOT to order just a front GLASS as you need the combination of display and digitalizer. The front glass thing by itself is a rip-off.
I think the biggest problem you might face is the repair *manual*. Unless some kind soul has spent considerable time compiling one that you can download, I don't think you will have any success disassembling the unit and getting it back together without breaking something else in the process
Mar 02, 2015 | Hannspree Tablets & eReaders
I have a HITACHI-AXM898U-Micro-Hi-Fi. The display screen has just stopped working. can you help me?
This one of the more difficult problems to locate, check display for cracked solder joints, overheated parts, open foil, or the backlight has failed.
Mar 16, 2012 | Audio Players & Recorders
I can't get any power to the unit
Tay to contact the nearest bose authorised servicing center because the spares of Bose wave radio is difficult to get out side. Also it uses a mutilayer circuit boar with SMD components. Only A well trained service tech will be able to rectify the fault.
Ajin
Feb 27, 2012 | Bose & Wave& Music System
How to connect my lcd kvm and make it display on sreen
You question is unclear. Please specify the makes and model of all devices. I typically use Rackmount Monitor Keyboard combos with integrated KVM Switches for larger server applications. I have used quiet a few units from KVMSwitchTech and they work pretty well.
Jan 18, 2012 | HP TFT7600 Rackmount KVM Switch
Dell 1545 laptop with white LED screen on start up. Works fine when connected to external screen via vga connector. Everything else works ok. Broken & remade connections between mobo & screen = no...
If the display works fine when connected to external screen via VGA connector then then the problem is either with the LCD display panel ( which consists of the display panel and inverter ) or the LCD cable that connects the LCD to the motherboard. You could try to re-seat the cable connection on the back of the LCD panel.
Aug 01, 2011 | Dell Inspiron 6000 Notebook
Suspected moisture in Furuno GPS/Plotter display
You need to determine if it's moisture or damage to the protective coating on the LCD glass. If the screen coating is damaged it will have patches or discoloration that resemble water spots like you see on windows and glasses exposed to hard water. If it's moisture between the glass and LCD you should be able to make out the tiny water droplets that are evenly spread throughout the screen. The only proper fix for a glass with damage to the protective coating is replacement of the bezel assembly. If it's moisture you can try inserting a few silica gel packs inside the unit. Don't try to disassemble the bezel (LCD/Screen) assembly. Just but the gel packs inside the 1650 chassis and give it a day or two. Otherwise, you're looking at factory repaire.
Jun 24, 2010 | GPS
"Rolling Screen/Static"
take the display apart and check the ribbon connectors to display unit sometimes your are lucky and find a loose plug connector
Aug 26, 2009 | Compaq Computers & Internet
Digimax S800 unclear image
Image on the display unclean meaning what? Dirty Screen? Out of Focus[ how do the images look on PC/TV screen? More detail please
Jul 09, 2007 | Samsung Digimax S600 Digital Camera
Garmin GPS 152 - GPS receiver - marine Antenna Logo
41 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
