Question about John Deere Garden
My john deere la 110 wont pick up fuel
It will start but wont pick fuel there is a fuel block on rear of the motor could that be the cause
    New Friend:
  • 17 Answers
There's a fuel pump mounted on the motor that's probably weak.
Posted on Jul 20, 2013
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
SOURCE: john deere 425 lawn tractor. it wont start but it
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
John Deere Buck 500. Unable to start
blocked main jet
blocked filter in the tank
tap has corroded internally and not allowing fuel through
carby full of water
needle and seat not opening to let fuel through
Jan 23, 2017 | John Deere 2006 Buck 500
I have a John Deere riding mower LA 110 automatic. When I engage it to cut grass, it just dies like a safety measure. What could be causing this? Happen while in the middle of cutting the lawn.
how thick/tall is the grass ?
when was it last serviced ?
if dying or shutting down while operating
could be an electrical / safety kill switch connection
or engine/ governor spark issue
before next startup do a visual
have a look to see everything is free and working under the cutting platform
Jun 17, 2016 | John Deere Garden
What is the correct tyre pressure for
NICE TRACTOR!
Tires
Front Dimensions15x6-6 turf
Air Pressure 110-138 kPa (16-20 psi)
Rear Dimensions26 x 12-12 turf
Air Pressure 96.5-110 kPa (14-16 psi)
Here is a link to the manual - very useful!:
http://manuals.deere.com/cceomview/omtcu29065_j0/Output/Index.html?tM=
Jan 03, 2015 | John Deere Garden
Where is the #1 cylinder located on a 1941 2 cylinder John Deere LA
pull both plugs and rotate motor till you get timing mark to top dead center on marker, feel for compression as you rotate motor BY HAND ONLY that will be #1
Sep 27, 2014 | Cars & Trucks
Our John Deere 110 is killing our grass in short stripes that look like equal signs
sounds like a fuel leak from the tank to the caburetor. Your mower has a fuel pump that pumps the fuel from the tank to the carburetor and when you are running the mower the fuel is leaking out the fuel line onto the grass. Check the fuel lines for cracks or splitting and replace it with fuel line from a lawn mower shop.
Jul 06, 2012 | John Deere Garden
Where should I start in trouble shooting my LA 115 model lawn tractor if it just won't crank. I tried to jump start it with jumper cables, but that didn't work ?
If the starter motor is actually turning the engine then the first thing to do is check the spark plug to see if you are actually getting a spark. If there is a spark, then move on to the fuel system to eliminate restrictions in the flow. The problem could be due to a dirty fuel filter, faulty fuel pump or solenoid fuel valve, no voltage on valve or dirt in the float bowl or a blocked float valve.
Have a look at these tips for troubleshooting lawnmower starting problems. They apply to tractors also:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
Aug 16, 2011 | John Deere Garden
My john deere 425 wont start cranks motor spins will run a few sec with starting fluid then dies
Check your fuel filter and see if it's clogged. You might be able to blow it out with an air hose if it is.
Feb 08, 2011 | John Deere 132 425 Lawn Tractorsnow...
Garden Logo
117 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
