Question about Dyson DC25 Vacuum
How to reset brush bar - Dyson DC25 Vacuum
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Dyson DC54 brush bar not rotating. Have removed all the hair, cleaned the brush and replaced, still not spinning.
    Brushbar not turning Clutch check - Dyson
    www.dyson.com/...dyson...not.../brushbar-not-turning-clutch-chec...
    DysonBrushbar not turning - Clutch check. Please ensure that your hands are clear of the soleplate and brushbar before completing this test. Clutch check.
    Resetting the brush bar (Official Dyson video) - YouTube
    ? 3:52
    https://www.youtube.com/watch?v=AiKnefEr7ns
    Jan 16, 2014 - Uploaded by AskDyson
    How to clear and reset the brush bar of your Dyson DC41 Mk2, DC55, ... Dyson DC41 Mk2, DC55, DC65, DC66 - Resetting thebrush bar (Official Dyson video) .... Dyson Cinetic DC52, DC54with the Musclehead™ floor tool ...
    Dyson DC44 - Remove & clean the Brush Bar - An owners ...
    ? 4:13
    https://www.youtube.com/watch?v=_0a71p84sp8
    Nov 12, 2012 - Uploaded by Tom Strong Reviews
    Here is the fantastic Dyson Digital Slim Mk2 DC44 Animal. (DC45 in ... Europe) Here I show how to remove and clean the Brush Barof any tr... ... It is and easy operation and one you need to do whenever the brush is not clear.
    Dyson DC54 Support - Turbine head not working properly
    https://www.dyson.com.au/.../dc54/dc54...not.../turbine-head-not-workin...
    Dyson DC54 Support - Turbine head not working properly. ... If you cannot clear an obstruction you may need to remove the brush bar. Use a coin to unlock the ...
    Jan 24, 2016 | Dyson Vacuums
    How do I get the brush to spin on a Dyson DC 24. I have thoroughly cleaned everything and pressed the reset button.
    Hi , if i am correct the brush bar is driven by a small electric motor inside the brush bar. It sounds as if the motor has gone or the small printed circuit board has a fault. You will have to get it checked.
    Mar 05, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
    How Do I reset my Dyson DC65
    Hi there, it's Jack at Dyson.
    Like most Dyson upright vacuums, DC65's brush bar is engineered to shut off for protection if something jams it. Once you've checked the cleaner head for obstructions and removed any threads or hair from the brush bar, you should be able to reset your machine as shown in the video:
    There's no physical reset button - the reset mechanism is built into the main on/off and brush control switches. Please note, the brush bar will never rotate when your machine is standing upright, so recline it into the normal vacuuming position before testing it.
    If you need any further advice from our experts after giving this a try, you're welcome to contact the Dyson Customer Helpline directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). In the unlikely event that a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
    Feb 24, 2015 | Dyson DC44 Animal Cordless Vacuum Handheld...
    Brush bar doesn't rotate dc24
    DC24's brush bar is engineered to shut off for protection if something jams it. Once you've checked the cleaner head for any obstructions, and removed any threads or hair from around the brush bar, you should be able to reset your machine as shown in our video guide:
    It may help to use something like the eraser-end of a pencil to press the red reset button - you should feel a click as it engages.
    Please note, the brush bar will never rotate when your machine is standing upright. Make sure you recline your DC24 into the normal vacuuming position before testing it.
    I'm confident this will resolve the issue, but if you would like some further advice from our experts, please call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
    Sep 27, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
    How do I reset my dyson dc25
    You may need a new belt if the brush bar motor is working properly. It could be the switch or brush bar motor if the motor does not run .
    Jul 06, 2014 | Dyson DC25 All Floors Bagless Upright...
    I have a Dyson dc17 I have changed the belt cleaned the brush bar clean the bar motor reset the switch and still when i vacuum the brush bar just stops does not rattle. does not do it on bare floors or...
    hooked rugs produce the highest amount of friction opposing the brush rotation, which can over heat the drive motor. try using a height setting that raises the brush so that it barely touches the pile. If this issue has been going on for some time, you may need to replace the drive motor.
    Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Where is the reset button on dyson dc25?
    I could be a switch, belt, brush bar motor or a wiring problem.
    Jun 19, 2014 | Dyson DC25 Animal Bagless Upright Vacuum
    Reset button inoperative
    Sounds like 1 of 4 possibilities
    1.The button next to your on switch is jammed.
    2. The Motor has burnt out within the head unit
    3. The PCB Unit is faulty wihin the head unit
    4. The thin wires running down the inside of the machine to the head unit hve br
    May 23, 2014 | Dyson Dc-18 "slim" Upright Model...
    Dyson Animal DC 28 brush bar removal
    I'm sorry to hear you're having difficulty with your DC28's brush bar. I've attached our video which shows the correct way to remove any obstructions and reset the machine, in case this is useful to you.
    The brush bar isn't designed to be removable, and attempting to remove it may void any guarantee on your machine. If you would like some further help it may be best if you contact us directly - our experts will be happy to confirm if we're able to repair your machine under the terms of our 5-year guarantee. You can reach us on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Apr 05, 2013 | Dyson DC28 Animal Bagless Upright Vacuum
    Dyson DC25 Vacuum Logo
    18 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
