Question about LG SteamDryer 7.3 Cu. Ft. 14-CycUltra-Large Capacity Steam Electric Dryer - White DLEX5170W
Reverse door swing - LG SteamDryer 7.3 Cu. Ft. 14-CycUltra-Large Capacity Steam Electric Dryer - White DLEX5170W
Can you reverse the door swing on a upright freezer. Frididaire model fffh17f1rwo
Hi Debbie,
I'm sorry, but I don't think so. There is a key that pops out when you lock it so I doubt the door can be reversed.
See page 8 of this manual under Optional Features and reversing the door swing is not listed.
On the positive side, it does have a high consumer satisfaction rate.
Happy 4th! :-)
Jul 05, 2017 | Freezers
Can I reverse the door swing on a Frigidaire LTF2140ES0 washer
Thank you for your inquiry, Sterling Calhoun!
From the information you have provided you would like to reverse the door swing on your Frigidaire washer. I have reviewed the manuals for your washer and I was unable to locate any directions on reversing the door. If you need any further assistance please feel free to reconnect. -Matt
Feb 26, 2015 | Frigidaire Washing Machines
How do I reverse the door swing?
Sorry but you can't - only the dryer allows you to reverse the door on these type of appliances...
Jun 15, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
Reverse door swing
Hi halej308 - Unfortunately Frigidaire front load washer doors cannot be reverse.
Sep 29, 2012 | Frigidaire Affinity ATF7000E Front Load...
How do I remove ge GBS20KBPACC handle for reverse door swing
You just grab the handle with both hands and pull/lift up like your trying to lift the fridge wirh the handle. It should disengage and then pull off.
Mar 30, 2012 | GE Refrigerators
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Door swing
yes any door swing can be reversed.take a good look and you will see the screws covered up with plastic covers .the door has to be removed first but check it out and you will see its not a big job get everything ready and it can be done within 10 minutes.adrian,,,,
Jun 29, 2010 | True 19 cu. ft. / 538 liter Commercial...
How do you reverse swing on door
Ity is not normlly possible to reverse the door on automatic washers, as they are not configured for this.
Tthankyou.
Dec 19, 2009 | Maytag EPIC MFW9700S Front Load Washer
Door swing on a LG WM0642HW
Sorry on that model you can not reverse the door.
Dec 18, 2008 | LG WM0642H Front Load
LG SteamDryer 7.3 Cu. Ft. 14-CycUltra-Large Capacity Steam Electric Dryer - White DLEX5170W Logo
15 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
