Question about Sharp R-1610 Microwave Oven
Microwave Fan Running for 24 hours
I was heating a casserole warmer gel pack yesterday morning. It said to have it in the microwave for 2 to 3 minutes. I set it for 3 minutes, took the trash out and when I came back in the gel pack had expanded to a huge bubble and looked like a jiffy pop popcorn item. The metal tray had been lifted off the holders and pushed the tray to the top of the microwave. I took the gel pack out, and the fan continued to run. When I got home last night the fan was still running and is as loud as a vacuum cleaner. I could not get it to shut off. Opening the door and closing didn't make any difference. The light remains on as the fan loudly blows. It now has been running for 24 hours straight. Is there a way on the control panel of the microwave to reset this? Or is my only option to go the service breaker and find the fuse? Is this a dangerous situation?
  • mbgirl Jan 05, 2008
    We were cooking food for Christmas in the oven (below our microwave) and the same thing happened to us. The fan switched on in the microwave and would not turn off. We allowed it to run for about 6 hours, then finally unplugged it. When we plug it back in it continues to run. All the power display as well on the microwave is off also... nothing responds. Any ideas?
You need replace the thermostat hood (TCO) is locad it behind the control panel whit two blue wires
Posted on Apr 07, 2009
  • Sharp Master
  • 9,174 Answers
Sounds like cycling the power line did it.
Posted on Sep 01, 2007
2 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: Roper Microwave fan won't shut off
Buffalo was pretty close, but glad the reset worked.
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 29, 2014 | Microwave Ovens
Convection side of Microwave takes forever to cook.
at 325 degrees should have been cooked so im saying that its not actually getting that hot...\
i think the thermostat might be buggered and not heating up properly or the heater element is playing up
its hard to change them or find witch one it can be so it would be so much easier for you to call a local repair guy
he will say the same one of those 2 but atleast he can test it there and then and give you a price thanks from chris plz rate this solution
Sep 29, 2008 | Microwave Ovens
THE FAN AND MICROWAVE TUBE RUN OFF THE ELECTRONIC TIMER. OPENING THE DOOR SHOULD SHUT IT ALL DOWN AND WHEN YOU CLOSE THE DOOR AGAIN YOU SHOULD NEED TO PRESS THE START BUTTON AGAIN. IF NOT, ITS SOUNDS LIKE AN ELECTRONIC RELAY IS LOCKED CLOSED ON THE TIMER BOARD.
Aug 28, 2007 | Sharp R-1610 Microwave Oven
I have a MV1604ST over the range microwave oven. After I made my daughter's breakfast this morning, the fan kicked on and will not shut off. It has been running for hours. The microwave still works and...
There si a sensor on the bottom of those Micros that is supposed to turn the fan on when it closes, meaning it is hot, then opening when it cools back down. I expect you have a bad thermal sensor. I have very seldom found these to go bad. Another thing that can cause it is a bad door switch back feeding voltage where it is not supposed to. It will make the fan that cools the magnetron run until the bad switch is replaced.
Aug 15, 2017 | LG MV1604ST 1000 Watts Microwave Oven
Our microwave quit HEATING this morning. What can
Could be the magnatron/thermal cut out seek pro advice
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
Nov 24, 2009 | DCS CMO-24-SS Convection/Microwave Oven
Cookworks microwave has stopped
Good Morning,
Check the unit for a blown fuse, if the fuse is good its the Magnatron Tube. Hope this helps and thank you for using FixYa!
Mar 30, 2009 | Microwave Ovens
Cannot heat
Sounds like it overheated, tripped the thermostat, then the thermostat reset. Chances are you have a bad magnetron. GE may have a campaign (not a "recall", mind you!) to offer free replacements if yours is a model that has a known history of problems with the magnetrons. I would call GE and ask them about that. *grin* GE Answer Center 1-800-626-2005 24 hours a day, 365 days a year
Dec 13, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1610 Microwave Oven Logo
125 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
