Question about Walthers Ho-athearn-5506-freightliner Tractor-hertz
Code "NO ENG" on dash freightliner Columbia 2005
Drove truck last night park it, and this morning try to start wont start and dash displays "NO ENG", I did check all connections clean it and put it back and also I clean all terminals with all 4 new batteries. PLEASE HELP ???
2 Suggested Answers
  • 13 Answers
SOURCE: eng turns strong, 2007 Freightliner Columbia 60 series Detroit
YOUR PROBLEM MAY NOT BE THE FUSE TO THE E.C.U. TRY THIS. 1. TURN ON THE KEY AND LOOK FOR THE CHECK ENGINE LIGHT (USUALLY YELLOW) AND THE STOP ENGINE LIGHT (USUALLY RED) WHEN YOU FIRST TURN ON THE KEY THEY SHOULD COME ON. AFTER ABOUT 5 SECONDS OR SO THEY SHOULD GO OFF. WAIT!!!!! ANOTHER 5 SECONDS AND SEE IF THEY COME ON. IF NOT TRY STARTING THE ENGINE.
IF THESE LIGHTS DO NOT COME ON WHEN YOU TURN ON THE KEY THEN CHECK THE WIRE THAT LEADS FROM THE POSITIVE SIDE OF ONE OF THE BATTERIES AND CONNECTS TO THE ECU.
IF THIS IS LOOSE IT WILL CAUSE THIS PROBLEM. THERE ALSO MAY BE AN INLINE FUSE ON THIS WIRE TO PROTECT THE ECU CHECK THE FUSE.
IF THE LIGHTS WENT OFF AND CAME BACK ON THEN YOUR ECU IS SHOWING A FAULT CODE. WITH THE ENGINE OFF AND THE KEY ON, PUSH THE ENGINE OVERRIDE BUTTON AND TAKE A PEN AND PAPER AND WRITE DOWN THE FAULT CODES. THE WAY YOU GET THE CODES IS BY WATCHING AND COUNTING THE NUMBER OF FLASHES OF THE YELLOW LIGHT AND THE RED LIGHT. FOR INSTANCE IF THE YELLOW FLASHES 5 TIMES AND THE RED FLASHES 3 THEN YOURE GETTING FAULT CODE 53. FIND YOUR CODE AND CALL THE SERVICE DEPOT AT THE DEALER AND FIND OUT THE DEFINITION OF THIS CODE.
LAST BUT NOT LEAST CHECK THE COOLANT AND ENGINE OIL BECAUSE THESE TWO THINGS WILL SHUT DOWN AN ELECTRONIC ENGINE FASTER THAN ANYTHING. ESPECIALLY IF A SENSOR HAS GONE BAD SUCH AS COOLANT LEVEL SENSOR OR OIL PRESSURE SENSOR. MY EMAIL IS JAMESFWALKERJR2006@YAHOO.COM HOPE I WAS ABLE TO POINT YOU IN THE RIGHT DIRECTION IF YOU HAVENT ALREADY SOLVED YOUR PROBLEM.
Posted on Aug 25, 2009
Cadillac 2006 won't crank drove fine last night this morning not start
make sure shifter is in park, take out of park and put back into park,then try to start . sometimes the linkage is not all the way there and the safety switch will not let the engine start
Aug 15, 2015 | Cadillac Cars & Trucks
Drove home last night and this morning my impala 2003 wont start
Security. Turn the key to run. Let it sit for ten minutes, off for thirty seconds. Then try to start. Do this three times for a relearn. Don't try to start.
Sep 07, 2014 | 2003 Chevrolet Impala
2007 Toyota Tundra wont start and low 4 WD light is blinking
Have you checked the gear position sensor? That would be my first place to start.
Feb 19, 2014 | 2007 Toyota Tundra
Will not Start after running two days
Try pulling engine codes , possible crank sensor.
Feb 04, 2014 | 1987 Oldsmobile Toronado
87 Olds Toronado put new gas tank, brake lines, plugs, gas filter, drove over a hundred miles(started to sound like a miss on the way back)and parked it for the night. Got in the next morning drove a
Since it is an older vehicle, check under the dash for any "rigging" that might have been done over the years. Start at the battery and follow all electrical wires that lead into the dashboard and fuse panels and check for any frayed or split lines that might be causing you to have a short circuit somewhere. that's what it sounds like to me. Unless you have a huge sound system with some 15" woofers in the trunk you shouldn't be experiencing any power shortages.
Drove my 1998 yukon last night and parked in the driveway where it sat thru the blizzard chicago had last night.tried to start it this am but no luck. checked spark,fuel @ the shrader,battery, ground...
pull dist cap off and dry with a hair drier. also make sure air cleaner is clean and dry. You dont need to unhook plug wires just tip cap on side and dry with heat. and also check ign wires plugs for moisture which shorts things out.
Feb 03, 2011 | 1998 GMC Yukon
I have a 92 buick park avenue drove it 40 miles home last night turned it off for 5 minutes got back in and it wont even turn over,if it is the security system what could be a possible fix.
I believe you're problem is more likely to be a bad connection on the battery....Clean the connectors and the towers and try again....Boiling water is good for cleaning, you may have to use a wire brush in which case watch out for your eyes, the oxidization is acid....After cleaning put a light coating of white petroleum jelly (Vasaline) NOT grease....Good luck Regards Johngee10
Oct 16, 2010 | 1991 Buick Park Avenue
Car is stuck in park. Wife drove home last night
TRansmission went on the car you may have to buy a new transmission
Mar 19, 2010 | 2001 Pontiac Grand Am SE
Car wont start, drove it home last night and this morning it wont start. lately everytime i tried to start it it would click once and it would start the second time.
1- Battery may be weak, need to recharge.
2- At this car age, the solenoid has corroded contact causing high resistance reducing the current delivered to the starter. Therefore you could hear click coming from the solenoid, but not started.
3- Your solenoid costs about $41
Aug 27, 2009 | 1995 Buick Park Avenue
Walthers Ho-athearn-5506-freightliner Tractor-hertz Logo
4,136 people viewed this question
Top Walthers Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Walthers Toy Expert? Answer questions, earn points and help others
