Question about Frigidaire Freezer 16.7 cu. ft. Upright Freezer
Freezer door screws - Frigidaire Freezer 16.7 cu. ft. Upright Freezer
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Josie - I am happy to assist you! However, I'm not certain I understand your question or concern? What exactly is the issue the unit is experiencing? Are you requesting door screw part numbers? Are you in need of a parts manual? Are the screws loose or damaged? With this information I can better address the issue at. Thank you and I look forward to your response.
Posted on Jul 18, 2013
CAN YOU TELL ME HOW TO CHANGE THE DOOR SEAL PLEASE ON UPRIGHT FREEZER?
There are a bunch of 1/4 screws around the door inside underneath the gasket. Make sure you unload all the food from the door. Unscrew the upper half first, remove half of old one and install a new one. Then the other half. Tip: Don't unscrew the screws all the way. Just loosen them up.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 20, 2011 | Maytag Freezer 20 cu. ft. Upright Freezer
Door was not shut tight. A loud buzzing sound recently went off and only stops when we unplug or turn off freezer. :(
loud buzzing I believe is an alarm that is waring you that the freezer is not cold enough. Door problems can be fixed. Test is to stick a dollar bill in the door and shut it. It should be a little hard to pull the bill out. Do this all over the door and find all the bad places. One problem is that the door can become warped by banging it against something or kids hanging on it etc. If you can see the warp you can actually bend the door back into place by holding the bottom of the door and moving the top in the necessary direction. Like jamming your foot against the bottom and pulling on the top or putting a box at the bottom of the door to hold it open and push the top. Next many time the bad fit door is because a hing has moved. All the hinges are adjustable. Usually you loosen the screws and move the door in the appropriate direction and re-tighten the screws. These screws are very tight so you need a big screwdriver and someone big to turn it. Lastly you can purchas a completely new door seal and put it in..
Sep 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer door does not seal on the bottom left side.
you can actually bend the door into shape if you can see that it is warped. If the freezer hing is on that corner then you can loosen the screw on that side and push the door into place and re-tighten the screws. You need a big screwdriver and a big person to get it done. you can test the repair with a dollar bill. Slip it in and close the door. It should take a little pull to pull it out. Go all around the door like that. anywhere it slides out easily you will have an air leak..
Sep 22, 2010 | Amana 16.8 cu. ft. / 476 liter Upright...
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Chest freezer lid repair
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
May 01, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
How do you adjust a Westinghouse 2 dooe refrigerator door
Loosen the top hinge screws.
Pull up on the door to where you want it.
While holding the door in place, re-tighten the screws.
Mar 11, 2009 | Frigidaire Freezer Refrigeration White...
How to replace the door seal on a frigidare upright freezer
most fridge door seals are attached to the door by screws. If you flap the seal up from the bottom you should see some screws. if you go to the site below it gives your guidance on replacing the seals on fridges, as all fridge seals are pretty generic you should find it useful
http://www.wikihow.com/Replace-a-Refrigerator-Door-Seal
I hope this helps
Dec 08, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Lock on freezer door
Yes, you can put a lock. Visit your nearest locksmith shop and ask them. There are so many varieties of locks. The 4 1/2 keyed Hasp Lock Guard security can be used for this, it can be any other brand. It is a door security lock, the screws are small so nothing will hurt your freezer. Just ask a in a locksmith store. They will know which kind of lock to give you.
Artgirlny
Jul 09, 2008 | Magic Chef 7 cu. ft. / 198 liter Chest...
Freezers Logo
48 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
