Question about RCA TruFlat 27F520T 27" TV
No sound remote not working - RCA TruFlat 27F520T 27" TV
Vizion sound bar not working with my 3 remotes.
The sound bar may have failed and can no longer receive signals from the remote controls.
Jun 07, 2018 | Televison & Video
Connected an RCA sound bar to my RCA tv an the remote control wont work anymore
You may have situated it so it is blocking the pickup for the remote. Your remote is talking but the TV can't hear it. Make sure no part of the front is blocked by the sound bar.
Apr 02, 2015 | RCA Televison & Video
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
Programming Universal Remote with RCA Sound System
You don't say whether you tried using the code search function to find something that works. As for the lack of a "sound system" button, you should be able to select any button other than TV to find a code.
Feb 13, 2014 | Sentry Safe Sentry RMC10 Universal Jumbo...
I got a new remote for 2003 dodge grand caravan, I programmed it using one of my old ones and now both old remotes don't work. What did i do wrong
Please note carefully that you must have one working remote before carrying out the following procedure. If you do not have the working remote then you have to consult the locksmith to reprogram the one with the help of a suitable key programmer.
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. A chime will sound afer each
additional remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
Dec 09, 2013 | Keyless Entry Remote Fob Clicker for 2002 ...
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
I NEED A REMOTE CONTROL FOR MY EA-506 SURROUND SOUND RECEIVER
Many surround sound systems don't work with universal remotes. They require factory remotes. I could not find any codes either.
Contact the manufacture of the surround sound receiver, go onto there website and use the contact link. Write them asking for a new remote and they will let you know how much a replacment cost.
Feb 12, 2009 | EA Sports SRU8010/17 Remote Control
Remote Code
THE SURROUND SOUND REMOTE THAT CAME WITH MINE IS AD-100MTRS . for the surround sound system for the ad-1100s dvd palyer.. my surround sound no longer works. i do havethis remote still.. where are you located.
e-mail me back at:
MONSTERMUSIC@AOL.COM
use suject-remote for surround sound system.
Feb 08, 2008 | Aspire Digital AD-1100S DVD Player
Sanyo (0525390)Sound problem
What model of Sanyo do you have?
1.With the TV turned on point the remote and push the mute button.
2. Did the sound ever work? If so what happen before the sound stopped working?
  JR57Gard
Oct 21, 2007 | RCA RCU410MS Remote Control
RCA TruFlat  27F520T 27" TV Logo
18 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
