Question about Polaroid PDM-0742 Portable DVD Player
Bad disc my portable dvd player consistantly says bad disc even when I have a perfectly good disc in it??? whats wrong with it, can I fix it?????
  • 6 more comments
  • Aerolaura Aug 28, 2007
    a regular cd that plays on any other dvd player......its not a rewritable disc or anything
    ive used multiple cd's by the way...same result, bad disc
  • Aerolaura Aug 29, 2007
    Cleaned it with both of your suggestions, I used a cotten swab with alcohol as well as a disc cleaner....and I checked to see if the laser works, it does. When I put a disk it, the top display immediately says, disc reading......then I hear the disc shuffling around and a beep every now and then. Then the display comes up.....bad disc every time, no matter if its a brand new DVD or not. What do you think??????
  • cynthia30815 Feb 09, 2008
    whenever i put in any disc, it reads bad disc. I have cleaned with dvd cleaner but i still get the same reading.
  • docorock Apr 12, 2008
    It will not play any of my DVD+RW media.Only discs purchased as movies(DVD Video format).It reads 'dirty disc' even though I can play them on my other players with no observed difficulty.I will return it if I can't play all my various disc types.According to the specifications,it should play them all!!
  • Anonymous Jun 01, 2008
    no matter what disc i put in the dvd player makes a bunch of loading noises, says "Disc loading" then says "Bad Disc"
  • Anonymous Nov 05, 2008
    It says disc loading, then, bad disc-it will not play. Help!
  • mjaco7 Jan 23, 2009
    My dvd player has been used maybe at most 3 times. I've had it for about 2 years. Now when I try to use it no matter whether its a brand new DVD or old one it says bad disc. I should have know better when I bought a Polaroid dvd player.
    President:
  • 814 Answers
1-866-289-5168 FOR ASSISTANCE. Try calling technical assistance at this number for help with you problem. Hope this helps you.
Posted on Apr 30, 2009
    Genius:
  • 2,985 Answers
What type of disk is you are trying to play?
Posted on Aug 28, 2007
  • Anonymous Aug 28, 2007
    It has played regular discs then in the past?
    If so try a laser cleaner.
    Or if the laser is visible when the lid is up - a cotton bud with alcohol to give a little gentle wipe then try.
    Other wise I think it implies - the laser has died.
    This will not be a repair option
  • Anonymous Aug 29, 2007
    Well it seems then this is a firmware fault.
    If it is fairly new return it to replacement.
    If you can't do that - get a new one
SOURCE:
My philips portable dvd player says "wrong disc" when trying to play a dvd. whats wrong?
The lens isnt reading the disc get a lense cleaner n run it twice that should solve the problem
Apr 07, 2013 | Philips DCP851 Portable DVD Player
My sylvania portable DVD player won't read discs the display says No Disc after the spin. What do I do?
I had same problem with a sylvania portable DVD: no disc. After cleaning the laser didn't work, I took the unit apart, and found that there is a small gear that moves the laser back and forth across the disc.. The gear could easily be misaligned with a rough bump along the drive.. All I did was realign the gear to the center where the disc was. Inside, there was even a small lever to pull back on to do this.. I also noticed a small Ribbon cable connecting the laser to the main board. Again, seemed nimble. I detached the ribbon, cleaned the connectors with alcohol and reattached. Happy to say, it works perfectly now. :). Good luck.
Oct 10, 2011 | Sylvania SDVD7027BL Portable DVD Player
Polaroid portable DVD player error code ''bad disc''
You'd need to open the unit, and the problem is either that the laser and the tray are misaligned, which can be tricky to fix even, or worse, you need a new laser. Either way, the Polaroid dvd player may not be worth getting repaired if it is no longer under warranty.
Good luck!!
Nov 29, 2009 | Televison & Video
Portable dvd player keeps saying bad disc
try cleaning the lens with a lens cleaner cd, if this doesn't work the lens itself is scratched or faulty and you will need to buy another dvd player
Nov 27, 2008 | Televison & Video
Getting "Bad Disc" message after Loading message...
If you've had it a long time and used it often, could be the lens is dirty or something wore down and it should be trashed since newer players have more features like usb ports.
Oct 17, 2008 | Astar PD-3060 Portable DVD Player
GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Oct 12, 2008 | GPX PDL705
Wrong disc
If this model displays Wrong Disc even when you play all kinds of CDs, you may want to buy a CD/DVD laser cleaner for it.
Does this solve the problem?
Aug 03, 2008 | Coby TF-DVD7005 Portable DVD Player
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Wrong Disc
It is a bad data cable from the dvd head to the main board
Feb 14, 2008 | Coby TF-DVD7005 Portable DVD Player
How can i fix my portable dvd player?
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
Apr 26, 2006 | Durabrand 8.5'' Portable DVD Player
Polaroid PDM-0742 Portable DVD Player Logo
599 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
