Question about LG 37LG30 37 in. LCD HDTV
LG LCD tv model number 37LG10-UM
"I have an LG LCD tv model number 37LG10-UM and the tv turns on but I just started getting some discoloration in my picture. Not sure what is causing this issue does anybody have some suggestions? I already did a capacitor check on the power supply board and checked its surrounding components."
aymantn
  • 109 Answers
SOURCE: lg 32 lcd tv will not turn on checked fuse in plug
eBook about LCD repair
Posted on Mar 17, 2010
  • 222 Answers
SOURCE: Need a new power supply. Where?
Try E-bay
Posted on Jun 06, 2010
Testimonial: "THanks."
info33
  • 72 Answers
SOURCE: LG 26LC7D LCD TV that turns on, but no pix
Here is a link for the manual - it might help - http://tv.manualsonline.com/manuals/mfg/lg/26lc7d_26lc7dc_32lc4d_42lc4d.html
Posted on Jul 03, 2010
SOURCE: I have just bought an LG LED LCD 3D TV (model
WOW we bought 2 of those tv,s..... 1 from sears and and had lines through the centre.. took it back and went to future shop and bought the same. within hours of turning it then off and back on the tv would not work. woud act like the remote was being used and it was on the table. took it back and bought a sanyo... no more problems...
Posted on Nov 21, 2010
  • 1779 Answers
SOURCE: My lg 42pc3dv just turns off and on. I removed the
You need to monitor your standby voltages first, to see how stable they are 5v-3.4v-12v. If they are stable then locate the ON command pin going to the inverter board and see if it is going High then Low. If it is then replace the main board.
Posted on Nov 27, 2010
Testimonial: "Good answer but where do i monitor the voltages at?"
I have a lg 50" plasma tv with a distorted, discoloration. The model number is 50ps11-ub. Not sure what circuit board/panel to purchase. Can you help me with this? Thanks
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Nov 27, 2016 | LG Televison & Video
I have a LG tv and it keeps turning on and off. What can i do to fix it ????
Without knowing the model code I cannot be sure . On certain model the harness cable from the power to main board needs to be replaced.
May 12, 2014 | Televison & Video
Hello, I have a lg lcd monitor. w1941s model. when I start my computer, it work for sometime. then it goes blank showing only the LG logo. then the power button doesnot work. it hang up glowing. again
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 06, 2014 | LG Computers & Internet
LG model 26LCF7D 2 1/2 years old tv when turning on it takes about 10-20 min for the picture to come up and sometimes woudl loose tone now after two week the whole tv doesnt turn on at all the screan comes...
Inside your LG there is a component call backlight inverter that is was cause of the loose of tone. Normally the part is located on the left side of the screen. You can call LG and they can give you the part number average cost is about $45 to $75.00 very easy to install.
Nov 02, 2010 | LG 26LC7DC 26 in. LCD HDTV
Green discoloration is bothering the whole screen.
Check the pins at both ends of the cable, also try it on another PC to make sure it is not the PC video card problem.
http://s807.photobucket.com/home/budm/allalbums
Jul 15, 2010 | LG Flatron L1750S 17" LCD Monitor
I am starting to get a discoloration in the bottom left side of my screen. It is slowly making it's way up to the middle of the screen.
If it is a tube type TV, probably needs degaussing. The screen within the crt becomes magnetized or external magnets from speakers are causing a problem. Sometimes changing the direction or position the tv faces causes degauss problems. If moving nearby speakers changes the discoloration, then speakers are too close or TV needs degaussing. Some high-end Asian tvs have E-W adjustment in users menu to correct this problem.
If it is RPTV 3 tube crt TV, maybe a convergence problem.
If it is DLP or LCD rear projection, probably optical engine failure.
What model is TV. Is picture normal in BW with color turned off?
easyab
Apr 22, 2010 | Televison & Video
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I loose my picture but i still get sound
Just try to reset so picture will come again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Got a 51" LG HD
The LCD panel can not be fixed, only replaced. Without the model number, I can not give you a cost, but expect the cost to exceed 1/2 of the original purchase price. Post hte model number and I'll get you the part number and cost.
Dan
Nov 07, 2008 | Televison & Video
Pictures has discoloration
From the picture it looks like the digital board or gama board. not a do it your self project. call a tech and expect $$$$.
If you get real lucky it may be a bad or lose connector.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
LG 37LG30 37 in. LCD HDTV Logo
160 people viewed this question
Computer Repairing
Computer Repairing
