I have a Toshiba laptop I got from a friend and I use to be able to get on it but now when I turn it on a blue strip appears and say enter password after three trys the laptop turns off. How do I fix this?
    Problem Solver:
  • 16 Answers
That is the bios password, in order to bypass that you would need to know the password, either ask your friend for the password, or you would need to remove the bios battery inside the laptop wait 10 seconds and place it back and turn on the laptop to reset the bios.
Posted on Jul 18, 2013
SOURCE: default bios password toshiba satellite a135-s2276
I have a Satellite A135-S2356 that had the same problem. I tried the solution from PCTServices above and it worked great.
"Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw."
Just short the two little solder pads and it worked great! I thought I would have to send it back to the manufacture but I am back in buisness. Thanks for the help.
Bryan
Posted on May 24, 2008
  • 16 Answers
what you need to do is pull both the laptop battery as well as the cmos battery. in some instances, the battery can be pulled, but on other models, i have seen the battery as an actual physical part on the motherboard or somewhere where it is not easily accessible, in which case you need to clear the cmos by using a jumper on the motherboard, since it is a laptop, they are all different. you may need to see if you can locate a copy of the motherboards schematics and go from there.
Posted on May 29, 2008
myob247
  • 1342 Answers
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Posted on Jun 03, 2008
  • 95 Answers
SOURCE: password
It means this machine is password protected..
Posted on Sep 01, 2008
  • 91 Answers
SOURCE: My Toshiba A215-S5818 Shows up enter password
The problem can be due to incorrect power on password prompt. This problem is noticed with some older BIOS versions. The system is looking for a non-existing power-on password.
The only solution for this is to send the system back to Toshiba. They will repair this problem free of cost.
Posted on Mar 10, 2010
Black screen blue box ENTER PASSWORD
If you would like to remove this BIOS password by yourself, you need to see this kind of video:
http://www.youtube.com/watch?v=SxGviSv7EoA
Mar 07, 2014 | Toshiba Satellite A135-S2276 Notebook
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
Turn on my laptop, screen thatv says Toshiba innovations pops up, cannot bypass by pressing anyb of the f1, f2, f3, ect...... goes to a black screen with a blue box asking for a password, after a few...
Oh be care full here some systems will only allow you a certain trys at entering the password then they will just stop functioning.Try moving on without entering a password at all(blank box etc)'
Good luck
Davey Snake!!!
Jul 20, 2011 | Toshiba Satellite C655-S5068 Notebook
My toshiba sat M115-s1061 forgot bios password. When I power on the laptop, it appears the scren with a blue box asking for: enter password.
http://answers.yahoo.com/question/index?qid=20100215063247AATJ4oQ
I found this. It doesn't sound good.
http://forum.notebookreview.com/toshiba/190972-toshiba-m115-s3094-bios-password-reset.html
This^^^
May 29, 2011 | Toshiba Satellite M115-S1061 Notebook
My Toshiba notebook computer turned off. Now there is a blank screen with a blue box that says 'enter password'
please enter the password if you created a password before. you have to reset bios if you cannot get in to the windows.
Feb 23, 2011 | Toshiba Satellite A135-S2276 Notebook
A blue enter password box appears - laptop then shuts down
you forgotton the password. I would boot it to safe mood and change the password under the control panel.
Dec 27, 2009 | Toshiba SATP L300D Notebook
There is a black screen that comes up asking for a password
Somebody got into the bios and entered either a hard drive or a bios password. You will have to know which one it is.
Mar 16, 2009 | Toshiba Satellite A135-S2386 Notebook
My laptop when it comes on
This is a BIOS or hard drive password, you need to enter the BIOS setup screen by pressing DEL, F1, F2, or a combination of keys. Within the BIOS setup you can disable the password save and exit.
Jan 28, 2009 | Toshiba Satellite A135-S2326 Notebook
Toshiba Tecra A8 EZ8512 Bios problem
Good day to you.
I have a toshiba Laptop with Bios Password problem. I cannot start my system anymore, cos the laptop is requesting for Bios password which I dont know or have.
Oct 25, 2008 | Toshiba Tecra A8-EZ8311 Notebook
Hello
HI,
YOU NEED TO "RESET" THE BIOS/CMOS SETTINGS OF THE LAPTOP... TO DO THAT, FIND THE CELL-BUTTON BATTERY AT THE BOTTOM PART OR SOMETIMES UNDER THE KEYBOARD, IT MEANS YOU NEED TO UNSCREW YOUR LAPTOP TO FIND THAT BATTERY AND "SHORT" IT...
HOPE THIS HELPS YOUR PROBLEM.... FIXYA ME ON THIS ONE...
Feb 17, 2008 | Toshiba Satellite P105-S6104 Notebook
Computers & Internet Logo
David Payne
David Payne
