Question about Motorsports
No power of fuel elec. pump
It has no power on electric fuel pump, is their any relay on it? or it has other problem on it? please help me.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 15 Answers
A fuel pump and its associated components are vital parts of a car engine's assembly. One particularly important part of the engine fuel delivery assembly, is the relay. It is part of the control system of a fuel pump and its failure can lead to start up problems. It helps if you know the major bad fuel relay symptoms which can help you in taking care of the problem in advance.
What is a Fuel Pump Relay?
The relay is a small device covered in plastic covering which has the basic function of controlling operation of fuel pump at ignition and switch off. Also known as a relay switch, it triggers on the fuel pump in action when you turn on the ignition switch. It again comes into action when the car engine is powered off to cease the functioning of fuel pump.
The fuel pump action is necessary for the initiation of the engine cycle. Therefore, the relay is an important link between ignition system and the fuel pump, in the electrical setup engine assembly. To summarize, the relay switches the fuel pump on and off at ignition and shut down. It is prone to failure due to oxidization. The relay itself is more likely to fail, than the fuel pump itself.
Relay Location
If you are wondering where the fuel pump is located, then you first need to know what it looks like. The relay is covered in a plastic case and has sprockets which act as the connecting mechanism that attaches it to the ignition assembly. The location of the relay may vary according to the car model. The most common relay location is underneath the dashboard, near the steering wheel. In some car models, they are located near the firewall of the engine. For those who are unfamiliar with what a firewall is, it is the wall behind engine assembly. Another common location for the relay is the fuse box under the car hood. Refer your car manual, that will surely have information about it.
Faulty Relay Symptoms
Now that we know about the location and function of the relay, let us see what are the signs and symptoms of a fuel pump malfunction. To identify the malfunctioning symptoms of any car part, you must observe its effect on working of connected parts. Every part of the engine assembly is linked to the working of other parts. So bad fuel pump symptoms can be identified by the effect of the relay malfunctioning on connected parts like the fuel pump and the car engine. Here are the prime symptoms:
Engine Goes On a Strike
One of the prime symptoms of a bad relay is the engine cranking up but not starting. This points towards a problem with the fuel delivery system and it may be that the relay that is the culprit.
Erratic Engine Function and Delayed Start
Erratic functioning of the engine at the start and delay in starting up can be an indication of a faulty relay. That's why, if you consistently notice a delay in engine starting, check the relay.
Absence of Fuel Pump Working Sound
Once the relay stops functioning, the fuel pump will not switch on and the familiar sound of fuel pump working will not be heard. Ears trained to hear the normal sounds made by the car at start will notice the difference.
So these were the major symptoms that you need to watch out for. Being alert and identifying such symptoms of car problems in advance can save you a lot of money that you would spend in car repairs.
Read more at Buzzle: http://www.buzzle.com/articles/bad-fuel-pump-relay-symptoms.html
Posted on Apr 23, 2014
    Sergeant:
  • 352 Answers
CHECK: UNDER HOOD POWER DISTRIBUTION CENTER FOR BLOWN MAXI-FUSE
YES THERE IS A RELAY
WHEN IGNITION SWITCH IS TURNED TO THE RUN (NOT START) POSITION...YOU SHOULD HERE A "WHIRRING" NOISE BRIEFLY FROM FUEL PUMP
Posted on Jul 26, 2013
No power to fuel pump
hi darlene.
this is all i could find.
Sounds like you might have an electrical issue. If all 4 wires on the relay had power, there is something wrong with the wiring. The relay wires should have ground on two wires, power on one wire and switched power on another wire. ... The wire coming from the fuel pump is the other ground wire.3 Feb 2016
Q: No power to fuel pump ' YourMechanic Answers
https://www.yourmechanic.com/question/no-power-to-fuel-pump_2
Isai RodriguezAutomotive Mechanic23 years of experienceTHANK ISAISounds like you might have an electrical issue. If all 4 wires on the relay had power, there is something wrong with the wiring. The relay wires should have ground on two wires, power on one wire and switched power on another wire. To activate the fuel pump the computer actually connects one of the ground wires to complete the circuit and send power to the fuel pump. The wire coming from the fuel pump is the other ground wire. Electrical wiring issues can be a nightmare if you don't have the appropriate wiring diagrams to see which wires go to where. A mechanic, such as one from YourMechanic, will have access to the proper schematics to help you
or go to this link and see if it helps you out some more.
No power to fuel pump Google Search
Nov 22, 2017 | Cars & Trucks
My holden vz was running poorly then stopped.i put a new fuel pump in early this year.now it its not pumping and i only have power to 1 pin on the fuel pump relay any advice where to look next?
Hi Kano my advise is take it to Holdens or call out a mech/elec tech to have a look there are a couple of easy checks which they can do which would be the next step. the reason I won't say what the checks are is due to saftey. If your not a tech you could cause more damage or even worse. they are electrical tests. Good luck
Jul 22, 2017 | Holden Cars & Trucks
Looking to change from vac. fuel pump to elec, pump
Tylon, Go for it, Electric pump may fix some difficult starting issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
MC54 250B Replace Fuel Pump Vacuum to Electric
Part 1 Parts you need for electric fuel pump install on your 150cc scooter...
Part 2 Facet electric fuel pump install into Flyscooters il bello 150cc...
Aug 18, 2016 | Cars & Trucks
S10 truck "88" wont start change fuel elc pump,relay ,starter nothing
Have you tested the pump relay to see if it is sending power to the fuel pump ?
Mar 12, 2014 | Chevrolet S 10 Cars & Trucks
F250 not geting gas? wont run
What year is the truck ? Yes it could be the pumps or anything electrical in the circuit including the pump relay.
Have you checked the relay to see if it is sticking open or closed ? And is it sending power to the pumps ?
Feb 17, 2014 | Ford F-250 Cars & Trucks
Installing an elec. fuel pump
Normally you would use a relay, and have something that is controlled by the key switch signal the relay to turn on.
May 09, 2013 | Cars & Trucks
Car will turn over but won't start. Through the
No noise from fuel pump when you turn over the car .First thing get voltage at fuel pump relay checked, is there 12 volt to the relay.If no, then problem is again the relay.--------- To reconfirm the problem, try other test, that is remove the relay and by pass the relay terminals with a jumper wire .Then with 12 volt external battery give power to fuel pump connector and see, if the fuel pump starts, then its clear that fuel pump relay is faulty.----------- Also other problem can be fuel pump inertia switch.If the inertia switch is faulty then also fuel pump will not start.-------- The fuel pump relay on a 1995 Ford Explorer is in the power distribution
box, in the engine compartment, driver's side near the firewall.----------
The fuel pump inertia switch is in the right front passenger area
it is below the dash but above the carpet in the right hand corner.--------
Its a push button type inertia switch.
Fuel Pump Activation
When ignition switch is turned to START position, PCM operates fuel pump relay to provide fuel for starting engine. PCM senses engine speed and shuts off fuel pump by opening ground circuit to fuel pump relay when engine stops or engine speed drops to less than 120 RPM. When ignition switch is in ON position, EEC power relay is energized (contacts closed). Power is provided to fuel pump relay and timer in PCM. Fuel pump receives power through fuel pump relay contacts.
Inertia Fuel Shutoff (IFS) Switch
All models use an electrical interrupt switch in fuel system. During a collision or vehicle rollover, electrical contacts within inertia switch open, shutting off fuel supply to electric fuel pump. Fuel supply is interrupted even when engine is running.
A reset button is located on switch assembly. If electrical circuit trips, vehicle will not restart until switch is reset. Fuel system should be inspected before resetting switch.
IFS switch is located under instrument panel, near right side of transmission hump.
----------- If the fuel pump relay, the inertia switch and fuel pump all checked ok, and fuel pump is working with direct 12 volt source to fuel pump.Then problem relates to computer.The computer (power control module, PCM) is faulty and has to be replaced.--------- This will help.Thanks.Helpmech.
Jul 17, 2011 | 1995 Ford Explorer
WHERE WOULD I FIND THE FUEL RELAY OR FUSE FOR 2004 FORD FREESTAR,ANYONE HAVE A DIAGRAHM OF WHERE IT IS.THANKS
The fuel pump relay is in the engine compartment fuse block at location K4/C-1051.
Jan 09, 2010 | 2004 Ford Freestar
1987 chrysler lebaron 2.5, car runs fine, then cuts out, after awhile it runs again. in-tank fuel pump whirrs when ignition is turned on but only for a second, the car seems to have elec. when it kicks out...
i have had simmilar problems with my dodge dynasty and in the end an ignition coil fixed the problem.the fuel does only run for a second the will not run again until it see engine speed
Aug 07, 2009 | 1989 Chrysler LeBaron
No elec power
sounds like ign control mod. problem with the exception of the horn issue.
Jul 23, 2008 | 1997 Dodge Intrepid
Motorsports Logo
352 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
