How make laptop respond quicker
Boot time is 5 minutes and program hangs
    Master:
  • 663 Answers
Scan your computer with an anti-virus.
Scan it with RadarSync and update the drivers.
Disable start up items.
Do a disc clean up.
Those are some of the things that you can do to make your computer run faster.
David
Posted on Jul 18, 2013
    Problem Solver:
  • 19 Answers
If you want to make your laptop respond quicker then you should identify the exact reason of it's slowing down. You should remove all unwanted files and use a best quality antivirus.
Energy management
Start your computer in SAFE MODE by pressing F8 as it's booting up and when you see the Options menu, select the 'Safe Mode with Networking' option. Do some research and see if there are any updates for that software on Lenovo's website. You might not even need that software and might be able to remove it while you're in Safe Mode.
Oct 20, 2013 | Lenovo Computers & Internet
Utorrent is not responding.
have you tried to reinstall utorrent? if so, and it still doesn't work, you can remove utorrent and then run ccleaner which you can download from piriform.com after running it, try and do the installation again. if still no help i'd try a different torrent program such as vuze.
May 09, 2012 | Computers & Internet
Getting hanged
try to boot into safe mode by pressing F8 while restarting..then in safe mode goto>start>Run>type msconfig>and in start up tab disable the un necessary programs...then restart
Apr 11, 2009 | Acer Aspire 4720 Notebook
A Windows Update (4 files, 2 security, one Silverlight, and another one) installed as recommended by MS. Almost immediately,after installs were completed, an ominous error message from Microsoft--to the...
I recommend that you uninstall sliverlight first. and reinstall IE7.
MS security updates usually doesn't cause any problem, but the other files may.
if you remember or go to control panel>>add and remove program. and click on show updates. select the updates that is most recent and deleted them.
you can always reinstall them from MS web site.
Mar 30, 2009 | Computers & Internet
Acer Aspire 9500 Temporaily hangs and won't boot
hi, the controller you speak of is indeed emmbeded on the board.
you might try removing your hdd and reseating , try the same with your ram and cd/dvd drive i have had this on a travelmate 2410 turned out to be the dvd drive needed reseating.
hope this helps
Feb 21, 2009 | Acer Aspire 9500 Notebook
Not getting display
when you start booting your laptop wait till you see second booting screen and start pressing F8 when new menu will be open choice last good know settings and press enter.
Dec 22, 2008 | Computers & Internet
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
Computer hangs after 5 minutes from boot
Check the CPU fan (working) and heat sink as these over time clog up with fluff and dirt overheating CPU also check the rear of power supply for blocked ventilation holes
Jul 20, 2008 | Intel Pentium 4 1.7G, 1.7 GHz...
Inspiron running at .00001% speed
Sounds like something software is causing the problem!
Do Ctl Alt Del
Locate the Task Manager Tab
Click on it
Click on Processes
Look at the CPU usage
See if there is a program consuming your processor
I have found that there are programs that run behind the scenes in the background of your PC without your knowledge and it is consuming CPU usage!
The other Solution would be to wipe your drive clean and do a clean install
Nov 25, 2007 | Dell Inspiron 8500 Notebook
Fujitsu C6387 slow to start
What may well be happening is that a peice of hardware, eg usb ports, network adapter, graphics driver or similair is struggling to find the driver for it and is hanging the boot up. It could also be a memory failure or a bios failure as the memory used by your system takes over after the first 64KB of built in bios memory. Start your laptop in safe mode (press F8) on start up, as this will load up with only the needed drivers, if it boots up quicker it may well a driver fault, it is then a process of illimination.
Apr 20, 2007 | Fujitsu Siemens LIFEBOOK C6387...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
