Question about GE 28112EE2 Cordless Phone
Cordless Phone I just bought the new GE 6.0 cordless phone with answering machine base and an additional handset.model 28112EE2 Set up was easy but the screen displays NEW VOICE MAIL but I do not have an answering service with my service provider. You can also name each handset but that does not display because of the voicemail message display. How can I erase the new voice mail on the screen ? Help Please
  • Anonymous Mar 19, 2014
    New message on screen: New Voice mail. Cannot get voicemails and cannot remove the message from the screen
    Problem Solver:
  • 15 Answers
You did record a message on the answerer, didn't you? Mine displayed that until I recorded the outgoing message for the answerer. You do not need any service from your phone provider. The answerer in the base unit simply records the caller's message when you don't answer after a set number of rings. The manual tells you how to name the handset, which is a nice feature if you don't wish to use "unit 1, unit 2, etc".
Posted on Dec 29, 2007
SOURCE:
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
Phone says OUT OF RANGE while on the base and won't work.
The handset has lost the link with the base. This link codes the handset to the base with a unique security code so others with the same phone cannot use your phone line.
If you changed the battery, try disconnecting the base telephone line and ac adapter for a while (1/2 hour or so if possible).
Remove the battery from the handset as well.
After 1/2 hour, install the battery in the handset, connect the telephone line and ac adapter to the base. Place the handset in the charging base and the link should be established. If not, the phone is defective.
[email protected]
May 07, 2009 | GE 27992GE5 Cordless Phone
Register phone
If it's the model 27851 it's as easy as setting each handset in the base (the answering machine part) for 20 seconds. That's it! Hope this helps.
Aug 10, 2008 | Uniden Cordless Phone
Reset the answering machine without the manual
GE 28112EE2 1.9 GHz Twin Cordless Phone
Flashing CL.
Lost Manual.
Can you help.
May 23, 2008 | GE 28112EE2 Cordless Phone
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Apr 02, 2008 | Lands Phones
6.0 GE cordless phone
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
Mar 24, 2008 | GE 28112EE2 Cordless Phone
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
Setting the number of rings to answer
Press "Mute" to setup handset, select "Ring to answer", here are 1,2,3,5,6,L choice. you can change to 3.
Dec 16, 2007 | GE 28112EE2 Cordless Phone
GE dECT 6.0 Cordless Model 28112 Series
On the base is a button next to the GE logo that says "Do Not Disturb". Pushing that button will enable and disable that feature
Dec 08, 2007 | GE 28112EE2 Cordless Phone
Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Oct 18, 2007 | GE 25881EE3 Phone
GE 28112EE2 Cordless Phone Logo
331 people viewed this question
Top GE Lands Phones Experts
Marvin
Marvin
Ekse
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
