Question about John Deere 300 / 316 Hydrostatic Tractors Part Manual
Clm250lts table saw
I need a table insert for a pro clm250lts can you help?
Can someone help me find a replacement table saw insert for model # 152.221140, part # OR91014
Sears is the place.
thanks for the inquiry and for using searspartsdirect.com.
the insert or91014 has changed to a new part of 27509.00, but will still be the equivalent of the original. the insert will just be the insert, none of the set screws or hardware come with it. if you have the original hardware and just need a replacement insert, you can use the originals with no issue.
hopefully this helps and let us know if we can be of any further assistance. thanks for using searspartsdirect.com.
152 2210040 Insert 152221040 Craftsman Table Sears PartsDirect
Dec 30, 2015 | Saws
2 questions re Craftsman Tablesaw 137.218072 since the young men in that dept at our Sears did not know what a table saw was!
You can find a nice quality feather board that will fit your table saw from www.leevalley.com. They have one that comes with both 5/8" and 3/4" table bars and sells for about $15. I have one and it works great, Look under the Woodworking tab and type in feather boards. Look at the brand Versatile Featherboards. http://www.leevalley.com/US/wood/page.aspx?p=60022&cat=1,240,45884,60022 You may want to call Lee Valley to see if they have a zero clearance insert that will fit your saw. Otherwise, order a new insert from Sears Parts Direct. From the picture on their website I believe it comes as a blank and you will need to cut the new opening in the insert. To do that lower the saw blade all the way below the table top, install the new insert, move the rip fence over top of the insert but not over where the saw blade would penetrate, turn on the saw, and slowly raise the blade up through the insert.
e1e75b0f-dc3b-4bbe-bf84-360a611e8e41.jpg b3efb051-1d00-43f6-bc27-d2f9d84da710.jpg
Oct 02, 2014 | Craftsman 10" Table Saw
Need to purchase delta 36-979 dado head table insert for 10' table saw
Use an appropriate pc of mdf that is same thickness of throat plate already installed. Use a router to flush trim to that throat plate. Now, insert and hold down with clamps and scrap panel. Raise Dado head ,while running, enough to do the job. This completes a zero clearance throat plate. No need to buy!
Dec 31, 2012 | Delta 36 979 10 Inch Left Tilt 1 1/2...
How to replace brush holders on dewalt table saw dw745
There is a small allen screw in the field housing holding the brush holders in.
Most often I have found, if the brush holders are needing replacement the motor housing also needs replacement - they heat up and the plastic cracks.
Dec 26, 2012 | Dewalt DW745 10" Compact Job Site Table...
Removing Pro-tech table saw blade, is the nut holding it reverse thread? or standard?
Ralph, the arbor thread on a left tilt table saw is "standard" thread direction - that is, when looking at the end of the arbor (which of course you can't do on a table saw) turn the nut in a clockwise direction to tighten, counterclockwise to loosen.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Garden
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Aug 02, 2010 | Craftsman 10" Table Saw
What is the number and letter code description mean on bosch saw blades? for instance pro 1072 sm. what does the sm stand for
The Pro 1072SM is a 10" 72 tooth blade for a Mitre saw. So the sm means "saw miter" I don't know why they reverse the words.
Likewise a Pro 1040CHB would be a 10" blade 40 Teeth and used for chipboard, hense the "CHB" at the end.
Dec 06, 2009 | Bosch Accessories Table/Miter Saws Blades
John Deere 300 / 316 Hydrostatic Tractors Part Manual Logo
88 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
