Question about Denon S-301
Protection light is activated since i installed extra speakers- nothing works now
Denon s-301 subwoofer. attached new speakers and it wont turn on.. both subwoofer and dvd player! protection light is on..
  • Beck Donohue
    Beck Donohue Jul 27, 2013
    how can i fix it...? :)
    Genius:
  • Denon Master
  • 1,054 Answers
What do you mean by extra speakers? If you hooked more than one speaker up to one output, you probably blew the amp.
Posted on Jul 18, 2013
  • Beck Donohue
    How do i go about fixing it...? thanks Steve K
2 Suggested Answers
  • 21 Answers
SOURCE: The left speaker of my
Try unplugging the right speaker and plugging the left speaker in the right port. If the speaker still sounds distorted then you know you have a brocken speaker. If it sounds normal then we know its not the speaker.
Posted on Sep 25, 2010
Protect light on bass box on s101
Here is what is in the manual:
PROTECT indicator
This indicator lights red when the system
cable is not properly connected or the
protection circuit in the subwoofer (DSW-
S101) is activated
Nov 09, 2013 | Denon Audio Players & Recorders
Denon s101 fault
From the Manual:
PROTECT indicator
S101) is activated
I have a denon avr-4802 receiver. I am looking to purchase new speakers for this system, but don't want to put too much into the speakers. Will the speakers from a denon s-302 work on this receiver? ...
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Denon-S-302-Home-Theater-Systems-manual/id/7046dj484/t/2/
http://www.retrevo.com/support/Denon-AVR-4802-Receivers-manual/id/363ag815/t/2/
Page 10. The S-302 uses a proprietary D-Sub25 system cable to the DSW-S302 subwoofer. Don't know if or why it has more than 2 active conductors. The other speakers have removable cable ends so they might work just fine.
Apr 24, 2011 | Denon AVR-4802 Receiver
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
No subwoofer signal
your out put signal circut bord is shorted out. It happens when there is static feed back from output continuity to an electric overload inside the unit. Then when you have a shorted board then it will eventually go into a protect mode and nothing will work ...just the power light will turn red and blink.
Just a suggestion.....Get rid of it while it has a bad sub output signal. you can get some money out of it.
I can always use extra parts for the other denons I work on....call me if you want...630-742-6587
Rick
Jul 07, 2008 | Denon AVR-1705 Receiver
I have Harman Kardon speakers and subwoofers connected to a Denon AVr 1508 receiver. All my five speakers are working but my subwoofer doesnt work. I m pretty sure I have connected the subwoofer properly...
There is a setting under your speaker setup to turn the subwoofer on. If speakers are set to small it auto matically sets the subwoofer to ON. If the speakers are set to large it turns the subwoofer off but you can manually adjust.
May 02, 2008 | Denon AVR-1506 Receiver
Protector flashing red when off.
If the speaker wires are shorted, it may be in protection mode. Try turning it on with no speakers attached.
If you've already done that and still have the same problem, it's broken and you should return it.
Dec 20, 2007 | Denon AVR688
Subwoofer heard when only B speakers selected
This is really weird. Normally, the subwoofer must be turned off when you turn on B speakers. But, hold on.. I have recently tried to do the same thing as you do, and the result is the same as yours. The problem is that you have to turn off A speakers completely when you activate Bs. If you have an A/B Speakers switch, first push the A to turn them off, after that press "B" to listen to music downstairs. I hope it works.
Apr 19, 2007 | Denon AVR-1603 Receiver
Denon S-301 Logo
98 people viewed this question
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
