Question about Lands Phones
Connecting dect 3135 to hs 950 headset
I have a HS 950 uniden headset that I want to connect to my uniden 3135 phone. I followed the instructions - pressed 'find hs'button on base, then 'volume' button on headset, the headset flashed quickly but there was no confirmation noises and both the headset and base just kept flashing until they got tired of it and stopped. Still no connection. Pressed 'reset' and tried again - still no result.
otacon
  • 1944 Answers
SOURCE: what is the password to connect handsfree with mobile
The passkey should be four zeros: 0000
Posted on Mar 27, 2008
SOURCE: Have purchased an Uniden SS
Frustrated Pel. packed it up and returned phones to store.
They replaced it with no trouble. The second phone WAS a dud !
Sorry to have wasted your time.
Pel.
Posted on Jul 24, 2008
  • 5 Answers
SOURCE: Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Posted on Jul 21, 2009
PCTechOnline
  • 532 Answers
SOURCE: Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Posted on Mar 21, 2010
  • 3278 Answers
SOURCE: I use twin Uniden DECT6.0 handsets, and on both,
Hello.
Here are some tips:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Posted on Aug 01, 2011
Hs 950 headset won't charge up can it be reset as new out of box
then prehaps you need to spend more money and buy another . LI ION batteries do have low limits and they can be reset but not by conumers
Jul 10, 2015 | Uniden Lands Phones
How to connect an HS 950 headset to Uniden DECT 9135
(I presume you have checked the headset is fully charged and powered on.)
Together with pressing "Find Headset" on the phone, you also have to press and hold "VOLUME +/-" for 5 seconds on the headset.
When the connection is made the headset LED will flash blue every 10 seconds.
I hope this helps.
May 11, 2014 | Uniden DECT 6.0 Cordless Phone ID
Handset msg says.."Press HS LOC
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here. The manual should have illustrations giving the locations of all buttons.
Sep 22, 2011 | Uniden DECT 6.0 Cordless Phone ID
My uniden DECT 6.0 has flashing red light with no message. Red light will not stop. This phone has no find hs key.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Sep 10, 2011 | Uniden DECT 6.0 Cordless Telephone...
I need a head set with ear piece for a Uniden phone
www.shopping.com/-uniden+earpiece - 45k
www.amazon.com/Uniden-HS-915-HandsFree-Behind-Microphone/dp/B0015AHRR8 - 238k
cgi.ebay.com.au/UNIDEN+PANASONIC+ORICOM+MOTOROLA-EARPIECE-FOR-CORDLESS_... - 94k
May 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
No connection withe nokia HS-36W bluetooth headset
First check your headset pair with other handsets if ok. your headset is ok. then check your hand set connection is ok.The default password of hs-36w is 0000
Jan 28, 2007 | Nokia 6230
Lands Phones Logo
120 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
